ScarletSwitch
How to set a Variable inside a Function
Sat Oct 15, 2016 8:39 pm
So I set a variable inside a function, but now the other functions don't know what the variable equals
My code is in a sense hat so sorry if it doesn't make sense
from random import randint
from sense_hat import SenseHat
from time import sleep
sense = SenseHat()
start = 0
if start == 0:
  sense.clear()
  start + 1
def y_integer():
  y = 1
def random_integer():
  randy = randint(1,7)
  print (randy)
def obstacle():
  y = y + 1
  if randy == 1:
    sense.set_pixel(randy,y,0,255,0)
    sense.set_pixel(randy + 1,y,0,255,0)
    sense.set_pixel(randy + 2,y,0,255,0)
    sense.set_pixel(randy + 3,y,0,255,0)
    sense.set_pixel(randy + 4,y,0,255,0)
    sense.set_pixel(randy + 5,y,0,255,0)
    sense.set_pixel(randy + 6,y,0,255,0)
  elif randy == 2:
  elif randy == 3:
  elif randy == 4:
  elif randy == 5:
  elif randy == 6:
  elif randy == 7:
obstacle()
sleep(1)
print ("this means it's working")
ERROR MESSAGE
UnboundLocalError: local variable 'y' referenced before assignment on line 51 in main.py
Re: How to set a Variable inside a Function
Sun Oct 16, 2016 3:19 pm
If you're going to post python code on the forum can you put it in [code]... your python goes here ...[/code] tags.
That makes the difference between
if code_tags <> "Used":
print ("Python is virtually unreadable")
else:
print ("Python retains the special syntax of left-hand whitespace")
And
else:
You may want to edit your post.
ScarletSwitch
Sun Oct 16, 2016 4:53 pm
edited. thanks
bensimmo
Sun Oct 16, 2016 5:31 pm
The function is never called and the function never returns it value, so it's only seen in that function.
Just set the variable to a number in the function you use it in at the start on its own if you need to.
EDITING as now I can test in https://trinket.io/sense-hat
basically what you are doing and the error is saying is y is a local variable (it's only seen and used in that one function).
BUT you are trying to tell it y=y+1, unfortunately y doesn't equal anything yet.
B.Goode
Sun Oct 16, 2016 5:38 pm
Same answer written a different way.
The first thing you do in the main program is call obstacle()
The first thing obstacle() does is y = y + 1
What is the value of y that you want to add 1 to? We don't know.
That's what the error message says...
bensimmo
Sun Oct 16, 2016 6:01 pm
sense = SenseHat()
#Set variables
y = 0  #SenseHat LED Row
start = 0
def obstacle(y):  #tell it to expect y as a variable
  if randy == 1:
  elif randy == 2:
  elif randy == 3:
  elif randy == 4:
  elif randy == 5:
  elif randy == 6:
  elif randy == 7:
#while true so that it actually loops, else it would only do it once.
while True:
  if start == 0:  # See if first run, if so make sure LED is clear, (could just run it before the while True:)
    sense.clear()
    start + 1
  randy = randint(1,7)  #set x column on hat
  y=y+1 #increment y, this will soon error out the LED
  print (randy)
  print (y)
  obstacle(y)  #Call obstacle function, telling it what y is equal to
  sleep(1)
Have a read through that see if you follow my crude code and comments. y will error out after a bit though and there are a few error left in...
Edit to add
https://trinket.io/python/5b068c4c6a
ScarletSwitch
Sun Oct 16, 2016 6:30 pm
while True:
  sleep(1)
This way it changes randy after every time it changes y. Any advice on how I can make randy stay the same while Y keeps adding 1 until it's off the SenseHat?
bensimmo
Mon Oct 17, 2016 4:45 pm
Put it before the whole loop.
ewaller
Mon Oct 17, 2016 5:29 pm
There are a couple ways to do what you need. The most Pythonic would be to organize the functions that need access to the variable into a class, then make it a class variable.
The more intuitive route for those learning python would be to declare the variable at the beginning of the program outside of any functions. Then, if a function needs to set the variable, declare the variable as global inside the function. Functions that only need to read the variable do not need (and should not have) the global. declaration.
sense = SenseHat()
start = 0
y=None
randy=None
if start == 0:
  sense.clear()
  start + 1
def y_integer():
  global y
  y = 1
  global randy
  print (randy)
def obstacle():
  global y
  y = y + 1
  if randy == 1:
  elif randy == 2:
  elif randy == 3:
  elif randy == 4:
  elif randy == 5:
  elif randy == 6:
  elif randy == 7:
obstacle()
sleep(1)
Note, for example, I did not declare raandy as global in obstacle. As it is not defined in the context, it Python looks to the global space. If one does assign a value to a variable in a function, the global is required, otherwise Python assumes it is a local variable that overrides the global space.
r3d4
Mon Oct 17, 2016 6:40 pm
bensimmo wrote:The function is never called and the function never returns it value, so it's only seen in that function.
see also : en.wikipedia.org/wiki/Scope_computer_science#Function_scope
