YodaVonBeck
rapsistill vs picam?
Mon Oct 03, 2016 8:02 am
Whats the pros and cons to using these to methods for capturing pictures?
Re: rapsistill vs picam?
Mon Oct 03, 2016 8:34 am
raspistill was always intended as a proof on principle/demo code, although it is used extensively all over the place. It's written in C, and uses the MMAL API to communicate with the GPU/ISP. Picam, which I am not so familiar with, is a Python library and application, I believe it also uses MMAL. The Python one is likely easier to modify/use, unless you are happy with C.
I'd try both, to see which fits your use case the best.
YodaVonBeck
Mon Oct 03, 2016 8:36 am
Thanks for your quick reply. Im new to the PiCam and have already used a script to build a timelapse code
import os
import time
import RPi.GPIO as GPIO
from datetime import datetime
# Grab the current datetime which will be used to generate dynamic folder names
d = datetime.now()
initYear = "%04d" % (d.year)
print (initYear)
initMonth = "%02d" % (d.month)
print (initMonth)
initDate = "%02d" % (d.day)
print (initDate)
initHour = "%02d" % (d.hour)
print (initHour)
initMins = "%02d" % (d.minute)
print (initMins)
# Define the location where you wish to save files. Set to HOME as default.
# If you run a local web server on Apache you could set this to /var/www/ to make them
# accessible via web browser.
folderToSave = "timelapse_" + str(initYear) + str(initMonth) + str(initDate) + str(initHour) + str(initMins)
os.mkdir(folderToSave)
# Set the initial serial for saved images to 1
fileSerial = 1
# Run a WHILE Loop of infinitely
while True:
   d = datetime.now()
   # Loop to only take pictures within timeframe
   if (d.hour>6 and d.hour<19):
   hour = "%02d" % (d.hour)
   print ('The hour is: '+ hour + ' taking a picture...')
   # Set FileSerialNumber to 000X using four digits
   fileSerialNumber = "%04d" % (fileSerial)
   # Capture the CURRENT time (not start time as set above) to insert into each capture image filename
   mins = "%02d" % (d.minute)
   # Define the size of the image you wish to capture.
   imgWidth = 1920 # Max = 2592
   imgHeight = 1080 # Max = 1944
   #print " ====================================== Saving file at " + hour + ":" + mins
   # Capture the image using raspistill. Set to capture with added sharpening, auto white balance and average metering mode
   # Change these settings where you see fit and to suit the conditions you are using the camera in
   os.system("raspistill -w " + str(imgWidth) + " -h " + str(imgHeight) + " -o " + str(folderToSave) + "/" + str(fileSerialNumber) +".jpg -sh 40 -awb auto -mm average -v")
   # Increment the fileSerial
   fileSerial += 1
   # Wait 60 seconds (1 minute) before next capture
   time.sleep(60)
 else:
   # Just trapping out the WHILE Statement
   print ("Doing nothing at this time - wait 10min and check the time again")
   time.sleep(600)
This works, so are you saying there is little point in changing this to the picam library?
cecco
Mon Oct 03, 2016 4:37 pm
Hi guys!
I have a quest. Could you describe the method to stream video from RASBERRYPIcamera to my own device (Raspberry). Or could you give me the command to do it :) I ll be very gratefull :)
Tue Oct 04, 2016 10:44 am
YodaVonBeck wrote:Thanks for your quick reply. Im new to the PiCam and have already used a script to build a timelapse code
import os
import time
d = datetime.now()
print (initYear)
print (initMonth)
print (initDate)
print (initHour)
print (initMins)
fileSerial = 1
while True:
   d = datetime.now()
   fileSerial += 1
   time.sleep(60)
 else:
   time.sleep(600)
Well, there is a timelapse mode build in to Raspistill, you could try that.
cecco wrote:Hi guys!
Please start a new thread with a descriptive title.
