Wheezy is just a Debian variant with two options you can run it in command line where it is to all intents and purposes a Linux server so if you obtain almost any of the Debian derived server images then your running the same (ok you will have a lot more memory available).
Typing startx activates the second state
The second state is what you will see once you run startx this is the RaspberryPi Gui (LXDE (Lightweight X11 Desktop Environment) you can find out more about this here
http://en.wikipedia.org/wiki/LXDE
The Default desktop has shortcuts for
Idle (Python 2.7.3),
Debian Refrence (Shortcut to the embedded refrence material on the Debian image),
Idle 3 (Python3.2.3),
Python Games (Shortcut to a menu of pre written games written in Python)
Scratch (Programming Language),
Midori (Webbrowser) ,
LXTerminal (Access to command line from the desktop),
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek
