Tregonsee
Where to place non-repository programs?
Tue Sep 20, 2016 2:50 pm
I have a program which is not available, nor will it be available, from the standard repositories. It runs perfectly if I place the folder on the desktop. Is there a recommended location for such programs which are not normally installed?
Tregonsee
ukscone
Re: Where to place non-repository programs?
Tue Sep 20, 2016 2:56 pm
normally you'd place the program/script itself in /usr/local/bin and anything that it requires in the relevant directory under /usr/local although some people you should use /opt.
my personal feelings is if it's installable (make install) it goes in /usr/local if it's untarable (a tarball of binaries,scripts etc) it goes in /opt
Tregonsee
Tue Sep 20, 2016 7:08 pm
Thanks for the guidance. I don't want to start with bad habits.
Treg
