Pi zero build help please
Posted: Thu Sep 15, 2016 1:36 am
by danA3141
Hi everyone. I am planning a mini laptop using a pi zero and a 7'' LCD. I have never used a pi before so I am not sure what parts I will need. I have repaired laptops for a living so should be OK putting it together . Can you guys help me pick the parts please.
Dan
Re: Pi zero build help please
Posted: Thu Sep 15, 2016 11:29 am
by BMS Doug
Pi zero
microSD card
Display interface board
Display
USB Hub
WIFI dongle
Bluetooth Dongle
USB Ethernet dongle
USB storage media
USB Powerbank
I'd suggest a Pi3 instead of the zero
Pi3 (Ethernet, 4x USB, Wifi and bluetooth on board)
microSD card
Official Raspberry Pi display
USB storage media
USB Powerbank
Posted: Thu Sep 15, 2016 1:53 pm
by danA3141
Thanks for you advice Doug!
Is it a big job to strip the Ethernet port and replace the double stacked usb's with single's to minimise the thickness of the board?
Posted: Thu Sep 15, 2016 1:59 pm
by drgeoff
danA3141 wrote:Is it a big job to strip the Ethernet port and replace the double stacked usb's with single's to minimise the thickness of the board?
Everything is relative. :)
So it is anywhere between simple and almost impossible (to still have a working RPi after the removals) depending on your skills and available equipment.
Posted: Thu Sep 15, 2016 2:00 pm
by Laurens-wuyts
It depends on how good you can solder and how good your tools are.
But it shouldn't be to difficult tho.
https://learn.adafruit.com/diet-raspberry-pi/overview
Laurens
Posted: Fri Sep 16, 2016 9:49 am
by BMS Doug
Laurens
Reading through the adafruit guide it sounds pretty hard work, Adafruit have since started stocking a solder removal alloy which might make the job easier, basically a low melting point solder which you use to dilute the solder on the board.
If you want a minimum profile device then an A+ with the Pi screen might be OK, I'm just conscious that you will want some connectivity (keyboard, mouse, WIFI, bluetooth, storage media, etc) so again a USB hub + dongles would be needed.
The official Pi screen connects to the display interface (not available on the Pi0) through a small interface board (supplied with the screen).
