Mahan_Micro
changing PI password as root
Tue Sep 13, 2016 7:09 am
Hi
I could install the NODE-RED on RPI2 (raspbian) and reboot it.
after installing, my RPI bootup as root and I dont have any access to my software and... that ready for PI user
I can't Enter with PI and it's password.
can you help me?
I want to Enter as PI user but I dont know how !?!??
If your Dreams Don't Scare You , They Aren't Big Enough
nl3prc
Re: changing PI password as root
Tue Sep 13, 2016 8:51 am
are you sure you use smal print when enthering user pi and password i think is raspberry
Mension1234
Wed Sep 14, 2016 3:37 am
Try entering this in the command line:
su - pi
If it prompts you for a password, the default one is 'raspberry'
Try taking a look at this thread as well: viewtopic.php?f=63&t=25345
Mahan_Micro
Wed Sep 14, 2016 6:15 am
Mension1234 wrote:Try entering this in the command line:
su - pi
thanks a lot dear friend !
now I can login as PI but I have new problem :
1_after every reset my RPI bootup as root and I must every time login to pi
2_I havn't pi desktop ! when I login as pi the pi's Desktop dont apear
do you know how I can set the PI for default user ???
Mension1234
Wed Sep 14, 2016 6:12 pm
Not sure about this one, try taking a look at the thread I linked to. It might have a solution for this.
Do you mean it's booting to the command line? Or it's just without the folders you had?
Mahan_Micro
Sat Sep 17, 2016 3:28 pm
Mension1234 wrote: Do you mean it's booting to the command line? Or it's just without the folders you had?
IT has a GUI when boot as ROOT, and I dont have my folders even login with PI
Mension1234
Sat Sep 17, 2016 4:03 pm
If you had files saved on user ROOT, they won't be transferred over to user PI. You have to manually find the files in the directory tree and copy them onto the PI desktop.
