vate
Time zone
Mon Sep 05, 2016 8:44 am
Dear all
Iam new in Raspberry PI,. I have a problem with the Raspberry pi date
when I run the command date
Mon 5 Sep 03:33:24 PET 2016 ( Peru Time (Standard Time))
However, when I checked the real PET time (in web server http://www.timeanddate.com/time/zones/pet) the time is:
PET time now 3:41:
I don't understand the 8 minutes difference, I've already configured the raspberry time zone according to my city (Lima.-Peru)
BR
Walter
nl3prc
Re: Time zone
Mon Sep 05, 2016 9:50 am
i also have two times.
the one in my windows is about 6 minutes slow i think this is becouse a diferent server is used
RaTTuS
Re: Time zone
Mon Sep 05, 2016 9:56 am
try
sudo /etc/init.d/ntp stop
sudo ntpd -q -g
sudo /etc/init.d/ntp start
Covfefe
epoch1970
Re: Time zone
Mon Sep 05, 2016 10:13 am
Linux, like a unix machine, counts time as the number of elapsed seconds since jan 1st, 1970, in coordinated universal time (UTC).
Then users can shift this UTC date/time to their own time zone, because everybody doesn't live in Greenwich, London. (https://en.wikipedia.org/wiki/List_of_UTC_time_offsets)
Your machine shows an inaccurate UTC date. Normally this is taken care of automatically by the NTP protocol.
The Pi is a little special in that it doesn't keep track of time that passes when it is powered down (there is no battery backed RTC unit.)
It could take a little while for the machine to sync to the correct UTC date after bootup.
There are quite a few threads on the forum related to NTP and timekeeping. I would advise patience first, and dig into these topics only if time doesn't get accurate after a few days of uptime. (Or use the recipe posted by RaTTus above to accelerate the process)
vate
Re: Time zone
Mon Sep 05, 2016 2:45 pm
Dear all
Thank for your answers. I got those results
[email protected]:~ $ sudo /etc/init.d/ntp stop
[ ok ] Stopping ntp (via systemctl): ntp.service.
[email protected]:~ $ sudo ntpd -q -g
sudo: ntpd: command not found
[email protected]:~ $ sudo /etc/init.d/ntp start
[....] Starting ntp (via systemctl): ntp.serviceJob for ntp.service failed. See 'systemctl status ntp.service' and 'journalctl -xn' for details.
failed!
I don't have the ntp service enabled:
[email protected]:~ $ timedatectl
Local time: Mon 2016-09-05 09:32:50 PET
Universal time: Mon 2016-09-05 14:32:50 UTC
RTC time: n/a
Time zone: America/Lima (PET, -0500)
NTP enabled: no
NTP synchronized: no
RTC in local TZ: no
DST active: n/a
BR
Walter
RaTTuS
Re: Time zone
Mon Sep 05, 2016 3:07 pm
I though ntp was installed by default ... in jessie
sudo apt-get install ntp
Covfefe
