X.Org X Server 1.17.2
Release Date: 2015-06-16
[ 27.744] X Protocol Version 11, Revision 0
[ 27.745] Build Operating System: Linux 3.8.11-2-ARCH armv7l Raspbian
[ 27.745] Current Operating System: Linux raspberrypi 4.4.19+ #906 Tue Aug 23 15:40:04 BST 2016 armv6l
[ 27.745] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=768 bcm2708_fb.fbheight=580 bcm2708.boardrev=0x10 bcm2708.serial=0x5ac96a75 smsc95xx.macaddr=B8:27:EB:C9:6A:75 bcm2708_fb.fbswap=1 bcm2708.uart_clock=48000000 bcm2708.disk_led_gpio=47 bcm2708.disk_led_active_low=0 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 27.746] Build Date: 11 January 2016 01:32:44PM
[ 27.747] xorg-server 2:1.17.2-1+rpi1 (http://www.debian.org/support)
[ 27.747] Current version of pixman: 0.33.3
[ 27.747] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 27.747] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 27.749] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Sep 2 11:59:15 2016
[ 27.838] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 27.881] (==) No Layout section. Using the first Screen section.
[ 27.881] (==) No screen section available. Using defaults.
[ 27.881] (**) |-->Screen "Default Screen Section" (0)
[ 27.881] (**) | |-->Monitor "<default monitor>"
[ 27.905] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 27.905] (**) | |-->Device "Allwinner A10/A13 FBDEV"
[ 27.905] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 27.906] (==) Automatically adding devices
[ 27.906] (==) Automatically enabling devices
[ 27.906] (==) Automatically adding GPU devices
[ 27.935] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/X11/misc".
[ 27.936] Entry deleted from font path.
[ 27.936] (Run 'mkfontdir' on "/usr/share/fonts/X11/misc").
[ 27.936] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 27.952] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 27.952] Entry deleted from font path.
[ 27.981] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 27.981] Entry deleted from font path.
[ 27.981] (==) FontPath set to:
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
built-ins
[ 27.982] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 27.982] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 27.982] (II) Loader magic: 0x7f80af00
[ 27.982] (II) Module ABI versions:
[ 27.982] X.Org ANSI C Emulation: 0.4
[ 27.982] X.Org Video Driver: 19.0
[ 27.982] X.Org XInput driver : 21.0
[ 27.983] X.Org Server Extension : 9.0
[ 27.984] (II) no primary bus or device found
[ 27.989] (II) LoadModule: "glx"
[ 28.030] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 28.514] (II) Module glx: vendor="X.Org Foundation"
[ 28.523] compiled for 1.17.2, module version = 1.0.0
[ 28.523] ABI class: X.Org Server Extension, version 9.0
[ 28.524] (==) AIGLX enabled
[ 28.524] (II) LoadModule: "fbturbo"
[ 28.525] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[ 28.550] (II) Module fbturbo: vendor="X.Org Foundation"
[ 28.550] compiled for 1.17.2, module version = 0.5.1
[ 28.551] Module class: X.Org Video Driver
[ 28.551] ABI class: X.Org Video Driver, version 19.0
[ 28.551] (II) FBTURBO: driver for framebuffer: fbturbo
[ 28.552] (++) using VT number 7
[ 28.566] (WW) Falling back to old probe method for fbturbo
[ 28.567] (II) Loading sub module "fbdevhw"
[ 28.567] (II) LoadModule: "fbdevhw"
[ 28.568] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 28.584] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 28.584] compiled for 1.17.2, module version = 0.0.2
[ 28.585] ABI class: X.Org Video Driver, version 19.0
[ 28.586] (II) FBTURBO(0): using /dev/fb0
[ 28.586] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 28.586] (II) FBTURBO(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 28.586] (==) FBTURBO(0): Depth 24, (==) framebuffer bpp 32
[ 28.587] (==) FBTURBO(0): RGB weight 888
[ 28.587] (==) FBTURBO(0): Default visual is TrueColor
[ 28.587] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[ 28.587] (II) FBTURBO(0): hardware: BCM2708 FB (video memory: 1740kB)
[ 28.588] (**) FBTURBO(0): Option "fbdev" "/dev/fb0"
[ 28.588] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[ 28.589] (II) FBTURBO(0): processor: ARM1176
[ 28.641] (II) FBTURBO(0): checking modes against framebuffer device...
[ 28.641] (II) FBTURBO(0): checking modes against monitor...
[ 28.641] (--) FBTURBO(0): Virtual size is 768x580 (pitch 768)
[ 28.641] (**) FBTURBO(0): Built-in mode "current"
[ 28.641] (==) FBTURBO(0): DPI set to (96, 96)
[ 28.642] (II) Loading sub module "fb"
[ 28.642] (II) LoadModule: "fb"
[ 28.643] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 28.658] (II) Module fb: vendor="X.Org Foundation"
[ 28.658] compiled for 1.17.2, module version = 1.0.0
[ 28.658] ABI class: X.Org ANSI C Emulation, version 0.4
[ 28.659] (==) Depth 24 pixmap format is 32 bpp
[ 28.711] (II) FBTURBO(0): using backing store heuristics
[ 28.830] (II) FBTURBO(0): can't load 'g2d_23' kernel module
[ 28.831] (II) FBTURBO(0): failed to enable the use of sunxi display controller
[ 28.831] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[ 28.831] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
[ 28.831] (II) FBTURBO(0): enabled fbdev copyarea acceleration
[ 28.832] (==) FBTURBO(0): Backing store enabled
[ 28.846] (==) FBTURBO(0): DPMS enabled
[ 28.846] (II) FBTURBO(0): failed to enable hardware cursor
[ 28.846] (II) FBTURBO(0): no 3D acceleration because the driver has been compiled without libUMP
[ 28.847] (II) FBTURBO(0): if this is wrong and needs to be fixed, please check ./configure log
[ 28.847] (==) RandR enabled
[ 29.356] (II) SELinux: Disabled on system
[ 29.399] (II) AIGLX: Screen 0 is not DRI2 capable
[ 29.399] (EE) AIGLX: reverting to software rendering
[ 32.177] (II) AIGLX: Loaded and initialized swrast
[ 32.177] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 35.083] (II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/event0)
[ 35.084] (**) Chicony USB Wireless HID Receiver: Applying InputClass "evdev keyboard catchall"
[ 35.084] (II) LoadModule: "evdev"
[ 35.085] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 35.147] (II) Module evdev: vendor="X.Org Foundation"
[ 35.147] compiled for 1.17.2, module version = 2.9.2
[ 35.148] Module class: X.Org XInput Driver
[ 35.148] ABI class: X.Org XInput driver, version 21.0
[ 35.148] (II) Using input driver 'evdev' for 'Chicony USB Wireless HID Receiver'
[ 35.148] (**) Chicony USB Wireless HID Receiver: always reports core events
[ 35.149] (**) evdev: Chicony USB Wireless HID Receiver: Device: "/dev/input/event0"
[ 35.190] (--) evdev: Chicony USB Wireless HID Receiver: Vendor 0x4f2 Product 0x420
[ 35.191] (--) evdev: Chicony USB Wireless HID Receiver: Found keys
[ 35.191] (II) evdev: Chicony USB Wireless HID Receiver: Configuring as keyboard
[ 35.191] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:04F2:0420.0001/input/input0/event0"
[ 35.191] (II) XINPUT: Adding extended input device "Chicony USB Wireless HID Receiver" (type: KEYBOARD, id 6)
[ 35.192] (**) Option "xkb_rules" "evdev"
[ 35.192] (**) Option "xkb_model" "pc102"
[ 35.192] (**) Option "xkb_layout" "us"
[ 35.193] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 37.132] (II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/event1)
[ 37.133] (**) Chicony USB Wireless HID Receiver: Applying InputClass "evdev keyboard catchall"
[ 37.133] (II) Using input driver 'evdev' for 'Chicony USB Wireless HID Receiver'
[ 37.133] (**) Chicony USB Wireless HID Receiver: always reports core events
[ 37.133] (**) evdev: Chicony USB Wireless HID Receiver: Device: "/dev/input/event1"
[ 37.135] (--) evdev: Chicony USB Wireless HID Receiver: Vendor 0x4f2 Product 0x420
[ 37.135] (--) evdev: Chicony USB Wireless HID Receiver: Found 1 mouse buttons
[ 37.135] (--) evdev: Chicony USB Wireless HID Receiver: Found scroll wheel(s)
[ 37.135] (--) evdev: Chicony USB Wireless HID Receiver: Found relative axes
[ 37.135] (--) evdev: Chicony USB Wireless HID Receiver: Found absolute axes
[ 37.135] (--) evdev: Chicony USB Wireless HID Receiver: Found absolute multitouch axes
[ 37.136] (--) evdev: Chicony USB Wireless HID Receiver: Found x and y absolute axes
[ 37.136] (--) evdev: Chicony USB Wireless HID Receiver: Found keys
[ 37.136] (II) evdev: Chicony USB Wireless HID Receiver: Forcing relative x/y axes to exist.
[ 37.136] (II) evdev: Chicony USB Wireless HID Receiver: Configuring as mouse
[ 37.137] (II) evdev: Chicony USB Wireless HID Receiver: Configuring as keyboard
[ 37.137] (II) evdev: Chicony USB Wireless HID Receiver: Adding scrollwheel support
[ 37.137] (**) evdev: Chicony USB Wireless HID Receiver: YAxisMapping: buttons 4 and 5
[ 37.137] (**) evdev: Chicony USB Wireless HID Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 37.137] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:04F2:0420.0002/input/input1/event1"
[ 37.138] (II) XINPUT: Adding extended input device "Chicony USB Wireless HID Receiver" (type: KEYBOARD, id 7)
[ 37.138] (**) Option "xkb_rules" "evdev"
[ 37.138] (**) Option "xkb_model" "pc102"
[ 37.138] (**) Option "xkb_layout" "us"
[ 37.139] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 37.207] (II) evdev: Chicony USB Wireless HID Receiver: initialized for relative axes.
[ 37.207] (WW) evdev: Chicony USB Wireless HID Receiver: ignoring absolute axes.
[ 37.209] (**) Chicony USB Wireless HID Receiver: (accel) keeping acceleration scheme 1
[ 37.209] (**) Chicony USB Wireless HID Receiver: (accel) acceleration profile 0
[ 37.237] (**) Chicony USB Wireless HID Receiver: (accel) acceleration factor: 2.000
[ 37.237] (**) Chicony USB Wireless HID Receiver: (accel) acceleration threshold: 4
[ 37.276] (II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/js0)
[ 37.277] (II) No input driver specified, ignoring this device.
[ 37.277] (II) This device may have been added with another device file.
[ 37.293] (II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/event2)
[ 37.293] (**) Chicony USB Wireless HID Receiver: Applying InputClass "evdev pointer catchall"
[ 37.294] (II) Using input driver 'evdev' for 'Chicony USB Wireless HID Receiver'
[ 37.294] (**) Chicony USB Wireless HID Receiver: always reports core events
[ 37.294] (**) evdev: Chicony USB Wireless HID Receiver: Device: "/dev/input/event2"
[ 37.295] (--) evdev: Chicony USB Wireless HID Receiver: Vendor 0x4f2 Product 0x420
[ 37.295] (--) evdev: Chicony USB Wireless HID Receiver: Found 3 mouse buttons
[ 37.295] (--) evdev: Chicony USB Wireless HID Receiver: Found scroll wheel(s)
[ 37.296] (--) evdev: Chicony USB Wireless HID Receiver: Found relative axes
[ 37.296] (--) evdev: Chicony USB Wireless HID Receiver: Found x and y relative axes
[ 37.296] (II) evdev: Chicony USB Wireless HID Receiver: Configuring as mouse
[ 37.296] (II) evdev: Chicony USB Wireless HID Receiver: Adding scrollwheel support
[ 37.297] (**) evdev: Chicony USB Wireless HID Receiver: YAxisMapping: buttons 4 and 5
[ 37.297] (**) evdev: Chicony USB Wireless HID Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 37.297] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.2/1-1.2:1.2/0003:04F2:0420.0003/input/input2/event2"
[ 37.297] (II) XINPUT: Adding extended input device "Chicony USB Wireless HID Receiver" (type: MOUSE, id 8)
[ 37.298] (II) evdev: Chicony USB Wireless HID Receiver: initialized for relative axes.
[ 37.357] (**) Chicony USB Wireless HID Receiver: (accel) keeping acceleration scheme 1
[ 37.358] (**) Chicony USB Wireless HID Receiver: (accel) acceleration profile 0
[ 37.358] (**) Chicony USB Wireless HID Receiver: (accel) acceleration factor: 2.000
[ 37.358] (**) Chicony USB Wireless HID Receiver: (accel) acceleration threshold: 4
[ 37.368] (II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/mouse0)
[ 37.368] (II) No input driver specified, ignoring this device.
[ 37.369] (II) This device may have been added with another device file.
[ 37.415] (II) config/udev: Adding input device eGalax Inc. USB TouchController Pen (/dev/input/event3)
[ 37.415] (**) eGalax Inc. USB TouchController Pen: Applying InputClass "evdev tablet catchall"
[ 37.415] (**) eGalax Inc. USB TouchController Pen: Applying InputClass "eGalax touch class"
[ 37.415] (II) LoadModule: "void"
[ 37.416] (II) Loading /usr/lib/xorg/modules/input/void_drv.so
[ 37.453] (II) Module void: vendor="X.Org Foundation"
[ 37.453] compiled for 1.15.99.904, module version = 1.4.0
[ 37.454] Module class: X.Org XInput Driver
[ 37.454] ABI class: X.Org XInput driver, version 21.0
[ 37.454] (II) Using input driver 'void' for 'eGalax Inc. USB TouchController Pen'
[ 37.454] (**) eGalax Inc. USB TouchController Pen: always reports core events
[ 37.455] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:0EEF:0001.0004/input/input3/event3"
[ 37.455] (II) XINPUT: Adding extended input device "eGalax Inc. USB TouchController Pen" (type: Void, id 9)
[ 37.457] (**) eGalax Inc. USB TouchController Pen: (accel) keeping acceleration scheme 1
[ 37.457] (**) eGalax Inc. USB TouchController Pen: (accel) acceleration profile 0
[ 37.458] (**) eGalax Inc. USB TouchController Pen: (accel) acceleration factor: 2.000
[ 37.458] (**) eGalax Inc. USB TouchController Pen: (accel) acceleration threshold: 4
[ 37.493] (II) config/udev: Adding input device eGalax Inc. USB TouchController Pen (/dev/input/mouse1)
[ 37.493] (**) eGalax Inc. USB TouchController Pen: Applying InputClass "eGalax mouse class"
[ 37.494] (II) Using input driver 'void' for 'eGalax Inc. USB TouchController Pen'
[ 37.494] (**) eGalax Inc. USB TouchController Pen: always reports core events
[ 37.494] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:0EEF:0001.0004/input/input3/mouse1"
[ 37.495] (II) XINPUT: Adding extended input device "eGalax Inc. USB TouchController Pen" (type: Void, id 10)
[ 37.497] (**) eGalax Inc. USB TouchController Pen: (accel) keeping acceleration scheme 1
[ 37.497] (**) eGalax Inc. USB TouchController Pen: (accel) acceleration profile 0
[ 37.497] (**) eGalax Inc. USB TouchController Pen: (accel) acceleration factor: 2.000
[ 37.497] (**) eGalax Inc. USB TouchController Pen: (accel) acceleration threshold: 4
[ 37.547] (II) config/udev: Adding input device eGalax Inc. USB TouchController (/dev/input/event4)
[ 37.547] (**) eGalax Inc. USB TouchController: Applying InputClass "evdev touchscreen catchall"
[ 37.547] (**) eGalax Inc. USB TouchController: Applying InputClass "eGalax touch class"
[ 37.548] (II) Using input driver 'void' for 'eGalax Inc. USB TouchController'
[ 37.548] (**) eGalax Inc. USB TouchController: always reports core events
[ 37.548] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:0EEF:0001.0004/input/input4/event4"
[ 37.549] (II) XINPUT: Adding extended input device "eGalax Inc. USB TouchController" (type: Void, id 11)
[ 37.581] (**) eGalax Inc. USB TouchController: (accel) keeping acceleration scheme 1
[ 37.581] (**) eGalax Inc. USB TouchController: (accel) acceleration profile 0
[ 37.581] (**) eGalax Inc. USB TouchController: (accel) acceleration factor: 2.000
[ 37.582] (**) eGalax Inc. USB TouchController: (accel) acceleration threshold: 4
[ 37.587] (II) config/udev: Adding input device eGalax Inc. USB TouchController (/dev/input/mouse2)
[ 37.587] (**) eGalax Inc. USB TouchController: Applying InputClass "eGalax mouse class"
[ 37.587] (II) Using input driver 'void' for 'eGalax Inc. USB TouchController'
[ 37.588] (**) eGalax Inc. USB TouchController: always reports core events
[ 37.588] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:0EEF:0001.0004/input/input4/mouse2"
[ 37.588] (II) XINPUT: Adding extended input device "eGalax Inc. USB TouchController" (type: Void, id 12)
[ 37.634] (**) eGalax Inc. USB TouchController: (accel) keeping acceleration scheme 1
[ 37.635] (**) eGalax Inc. USB TouchController: (accel) acceleration profile 0
[ 37.635] (**) eGalax Inc. USB TouchController: (accel) acceleration factor: 2.000
[ 37.635] (**) eGalax Inc. USB TouchController: (accel) acceleration threshold: 4
[ 51.805] (II) config/udev: Adding input device eGalaxTouch Virtual Device for Single (/dev/input/mouse3)
[ 51.805] (**) eGalaxTouch Virtual Device for Single: Applying InputClass "eGalax mouse class"
[ 51.806] (II) Using input driver 'void' for 'eGalaxTouch Virtual Device for Single'
[ 51.806] (**) eGalaxTouch Virtual Device for Single: always reports core events
[ 51.806] (**) Option "config_info" "udev:/sys/devices/virtual/input/input6/mouse3"
[ 51.807] (II) XINPUT: Adding extended input device "eGalaxTouch Virtual Device for Single" (type: Void, id 13)
[ 51.809] (**) eGalaxTouch Virtual Device for Single: (accel) keeping acceleration scheme 1
[ 51.809] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration profile 0
[ 51.809] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration factor: 2.000
[ 51.809] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration threshold: 4
[ 51.821] (II) config/udev: Adding input device eGalaxTouch Virtual Device for Single (/dev/input/js1)
[ 51.822] (**) eGalaxTouch Virtual Device for Single: Applying InputClass "eGalax joystick class"
[ 51.822] (II) Using input driver 'void' for 'eGalaxTouch Virtual Device for Single'
[ 51.822] (**) eGalaxTouch Virtual Device for Single: always reports core events
[ 51.823] (**) Option "config_info" "udev:/sys/devices/virtual/input/input6/js1"
[ 51.823] (II) XINPUT: Adding extended input device "eGalaxTouch Virtual Device for Single" (type: Void, id 14)
[ 51.825] (**) eGalaxTouch Virtual Device for Single: (accel) keeping acceleration scheme 1
[ 51.825] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration profile 0
[ 51.826] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration factor: 2.000
[ 51.826] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration threshold: 4
[ 51.828] (II) config/udev: Adding input device eGalaxTouch Virtual Device for Single (/dev/input/event5)
[ 51.829] (**) eGalaxTouch Virtual Device for Single: Applying InputClass "evdev pointer catchall"
[ 51.829] (**) eGalaxTouch Virtual Device for Single: Applying InputClass "eGalax virtual class"
[ 51.829] (II) Using input driver 'evdev' for 'eGalaxTouch Virtual Device for Single'
[ 51.830] (**) eGalaxTouch Virtual Device for Single: always reports core events
[ 51.831] (**) evdev: eGalaxTouch Virtual Device for Single: Device: "/dev/input/event5"
[ 51.831] (--) evdev: eGalaxTouch Virtual Device for Single: Vendor 0xeef Product 0x10
[ 51.832] (--) evdev: eGalaxTouch Virtual Device for Single: Found 9 mouse buttons
[ 51.832] (--) evdev: eGalaxTouch Virtual Device for Single: Found absolute axes
[ 51.832] (--) evdev: eGalaxTouch Virtual Device for Single: Found x and y absolute axes
[ 51.832] (--) evdev: eGalaxTouch Virtual Device for Single: Found absolute touchscreen
[ 51.832] (II) evdev: eGalaxTouch Virtual Device for Single: Configuring as touchscreen
[ 51.833] (**) evdev: eGalaxTouch Virtual Device for Single: YAxisMapping: buttons 4 and 5
[ 51.833] (**) evdev: eGalaxTouch Virtual Device for Single: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 51.833] (**) Option "config_info" "udev:/sys/devices/virtual/input/input6/event5"
[ 51.834] (II) XINPUT: Adding extended input device "eGalaxTouch Virtual Device for Single" (type: TOUCHSCREEN, id 15)
[ 51.834] (II) evdev: eGalaxTouch Virtual Device for Single: initialized for absolute axes.
[ 51.836] (**) eGalaxTouch Virtual Device for Single: (accel) keeping acceleration scheme 1
[ 51.836] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration profile 0
[ 51.837] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration factor: 2.000
[ 51.837] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration threshold: 4
