unixhacker
X mouse frozen at upper left
Fri Sep 02, 2016 10:28 am
Setup: Raspberry Pi (not 2) model B, FreeBSD 11.0, xorg pkg installed. PS/2 keyboard and mouse connected through TrendNet PS/2-to-USB adapter. Mouse works correctly in console mode.
X will not autoconfigure; it can't seem to find video. I created an xorg.conf to tell it to use the scfb driver, and that worked, except for the mouse.
The cursor starts off in the screen center, but as soon as you touch the mouse, the cursor jumps to the upper left corner and stays there forever, regardless of mouse movement. Mouse button clicks work as expected to get twm to bring up the application windows (all stacked on top of each other in the upper left). It's apparent that X can hear the mouse; it's just not paying attention to mouse movements.
I've played at adding mouse configuration to my minimal xorg.conf. I changed protocol auto to protocol ps/2, and the mouse didn't work at all. I changed device /dev/sysmouse to /dev/ums0 and the mouse didn't work at all. I'm out of ideas there.
I've tried a different PS/2 mouse without effect. I tried vtwm instead of twm, but the mouse behavior is unchanged.
(Just in case it's relevant: occasionally the keyboard is unresponsive in console mode after system startup. Unplugging and replacing the USB adapter fixes the problem. The mouse doesn't have this problem.)
Any help appreciated. Thanks.
(BTW, I tried to attach Xorg.0.log, but it won't allow the .log extension; tried .txt, and it won't allow that, either. What extensions does it like?)
nl3prc
Re: X mouse frozen at upper left
Fri Sep 02, 2016 12:13 pm
i have a simular problem with the medion usb mouse i use.
It seems to be not workin properly
i now use the touchscreen of my screen to select items
its poperly a hardware problem thats not compateble with your system
unixhacker
Fri Sep 02, 2016 7:17 pm
Thanks for your reply.
I rather doubt that it's a hardware problem, since the mouse works perfectly in console mode. I've since tried a USB mouse, but the same problem persists. It would appear to be an X problem, but I know other folks have Xorg working on a Pi.
nl3prc
Fri Sep 02, 2016 7:55 pm
what is in the xorg log /var/log/Xorg.0.log
for my touchscreen i had to install things like below
apt-get install xorg xutils xserver-xorg xterm xserver-xorg-video-fbdev xserver-xorg-video-vesa
nl3prc
Sat Sep 03, 2016 9:15 am
my Xorg.log looks like below
X.Org X Server 1.17.2
Release Date: 2015-06-16
[    27.744] X Protocol Version 11, Revision 0
[    27.745] Build Operating System: Linux 3.8.11-2-ARCH armv7l Raspbian
[    27.745] Current Operating System: Linux raspberrypi 4.4.19+ #906 Tue Aug 23 15:40:04 BST 2016 armv6l
[    27.745] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=768 bcm2708_fb.fbheight=580 bcm2708.boardrev=0x10 bcm2708.serial=0x5ac96a75 smsc95xx.macaddr=B8:27:EB:C9:6A:75 bcm2708_fb.fbswap=1 bcm2708.uart_clock=48000000 bcm2708.disk_led_gpio=47 bcm2708.disk_led_active_low=0 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    27.746] Build Date: 11 January 2016  01:32:44PM
[    27.747] xorg-server 2:1.17.2-1+rpi1 (http://www.debian.org/support)
[    27.747] Current version of pixman: 0.33.3
[    27.747] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    27.747] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    27.749] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Sep  2 11:59:15 2016
[    27.838] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    27.881] (==) No Layout section.  Using the first Screen section.
[    27.881] (==) No screen section available. Using defaults.
[    27.881] (**) |-->Screen "Default Screen Section" (0)
[    27.881] (**) |   |-->Monitor "<default monitor>"
[    27.905] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[    27.905] (**) |   |-->Device "Allwinner A10/A13 FBDEV"
[    27.905] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[    27.906] (==) Automatically adding devices
[    27.906] (==) Automatically enabling devices
[    27.906] (==) Automatically adding GPU devices
[    27.935] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/X11/misc".
[    27.936] 	Entry deleted from font path.
[    27.936] 	(Run 'mkfontdir' on "/usr/share/fonts/X11/misc").
[    27.936] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    27.952] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    27.952] 	Entry deleted from font path.
[    27.981] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    27.981] 	Entry deleted from font path.
[    27.981] (==) FontPath set to:
	/usr/share/fonts/X11/100dpi/:unscaled,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	built-ins
[    27.982] (==) ModulePath set to "/usr/lib/xorg/modules"
[    27.982] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    27.982] (II) Loader magic: 0x7f80af00
[    27.982] (II) Module ABI versions:
[    27.982] 	X.Org ANSI C Emulation: 0.4
[    27.982] 	X.Org Video Driver: 19.0
[    27.982] 	X.Org XInput driver : 21.0
[    27.983] 	X.Org Server Extension : 9.0
[    27.984] (II) no primary bus or device found
[    27.989] (II) LoadModule: "glx"
[    28.030] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    28.514] (II) Module glx: vendor="X.Org Foundation"
[    28.523] 	compiled for 1.17.2, module version = 1.0.0
[    28.523] 	ABI class: X.Org Server Extension, version 9.0
[    28.524] (==) AIGLX enabled
[    28.524] (II) LoadModule: "fbturbo"
[    28.525] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[    28.550] (II) Module fbturbo: vendor="X.Org Foundation"
[    28.550] 	compiled for 1.17.2, module version = 0.5.1
[    28.551] 	Module class: X.Org Video Driver
[    28.551] 	ABI class: X.Org Video Driver, version 19.0
[    28.551] (II) FBTURBO: driver for framebuffer: fbturbo
[    28.552] (++) using VT number 7
[    28.566] (WW) Falling back to old probe method for fbturbo
[    28.567] (II) Loading sub module "fbdevhw"
[    28.567] (II) LoadModule: "fbdevhw"
[    28.568] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    28.584] (II) Module fbdevhw: vendor="X.Org Foundation"
[    28.584] 	compiled for 1.17.2, module version = 0.0.2
[    28.585] 	ABI class: X.Org Video Driver, version 19.0
[    28.586] (II) FBTURBO(0): using /dev/fb0
[    28.586] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    28.586] (II) FBTURBO(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    28.586] (==) FBTURBO(0): Depth 24, (==) framebuffer bpp 32
[    28.587] (==) FBTURBO(0): RGB weight 888
[    28.587] (==) FBTURBO(0): Default visual is TrueColor
[    28.587] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[    28.587] (II) FBTURBO(0): hardware: BCM2708 FB (video memory: 1740kB)
[    28.588] (**) FBTURBO(0): Option "fbdev" "/dev/fb0"
[    28.588] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[    28.589] (II) FBTURBO(0): processor: ARM1176
[    28.641] (II) FBTURBO(0): checking modes against framebuffer device...
[    28.641] (II) FBTURBO(0): checking modes against monitor...
[    28.641] (--) FBTURBO(0): Virtual size is 768x580 (pitch 768)
[    28.641] (**) FBTURBO(0):  Built-in mode "current"
[    28.641] (==) FBTURBO(0): DPI set to (96, 96)
[    28.642] (II) Loading sub module "fb"
[    28.642] (II) LoadModule: "fb"
[    28.643] (II) Loading /usr/lib/xorg/modules/libfb.so
[    28.658] (II) Module fb: vendor="X.Org Foundation"
[    28.658] 	compiled for 1.17.2, module version = 1.0.0
[    28.658] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    28.659] (==) Depth 24 pixmap format is 32 bpp
[    28.711] (II) FBTURBO(0): using backing store heuristics
[    28.830] (II) FBTURBO(0): can't load 'g2d_23' kernel module
[    28.831] (II) FBTURBO(0): failed to enable the use of sunxi display controller
[    28.831] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[    28.831] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
[    28.831] (II) FBTURBO(0): enabled fbdev copyarea acceleration
[    28.832] (==) FBTURBO(0): Backing store enabled
[    28.846] (==) FBTURBO(0): DPMS enabled
[    28.846] (II) FBTURBO(0): failed to enable hardware cursor
[    28.846] (II) FBTURBO(0): no 3D acceleration because the driver has been compiled without libUMP
[    28.847] (II) FBTURBO(0): if this is wrong and needs to be fixed, please check ./configure log
[    28.847] (==) RandR enabled
[    29.356] (II) SELinux: Disabled on system
[    29.399] (II) AIGLX: Screen 0 is not DRI2 capable
[    29.399] (EE) AIGLX: reverting to software rendering
[    32.177] (II) AIGLX: Loaded and initialized swrast
[    32.177] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    35.083] (II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/event0)
[    35.084] (**) Chicony USB Wireless HID Receiver: Applying InputClass "evdev keyboard catchall"
[    35.084] (II) LoadModule: "evdev"
[    35.085] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    35.147] (II) Module evdev: vendor="X.Org Foundation"
[    35.147] 	compiled for 1.17.2, module version = 2.9.2
[    35.148] 	Module class: X.Org XInput Driver
[    35.148] 	ABI class: X.Org XInput driver, version 21.0
[    35.148] (II) Using input driver 'evdev' for 'Chicony USB Wireless HID Receiver'
[    35.148] (**) Chicony USB Wireless HID Receiver: always reports core events
[    35.149] (**) evdev: Chicony USB Wireless HID Receiver: Device: "/dev/input/event0"
[    35.190] (--) evdev: Chicony USB Wireless HID Receiver: Vendor 0x4f2 Product 0x420
[    35.191] (--) evdev: Chicony USB Wireless HID Receiver: Found keys
[    35.191] (II) evdev: Chicony USB Wireless HID Receiver: Configuring as keyboard
[    35.191] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:04F2:0420.0001/input/input0/event0"
[    35.191] (II) XINPUT: Adding extended input device "Chicony USB Wireless HID Receiver" (type: KEYBOARD, id 6)
[    35.192] (**) Option "xkb_rules" "evdev"
[    35.192] (**) Option "xkb_model" "pc102"
[    35.192] (**) Option "xkb_layout" "us"
[    35.193] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    37.132] (II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/event1)
[    37.133] (**) Chicony USB Wireless HID Receiver: Applying InputClass "evdev keyboard catchall"
[    37.133] (II) Using input driver 'evdev' for 'Chicony USB Wireless HID Receiver'
[    37.133] (**) Chicony USB Wireless HID Receiver: always reports core events
[    37.133] (**) evdev: Chicony USB Wireless HID Receiver: Device: "/dev/input/event1"
[    37.135] (--) evdev: Chicony USB Wireless HID Receiver: Vendor 0x4f2 Product 0x420
[    37.135] (--) evdev: Chicony USB Wireless HID Receiver: Found 1 mouse buttons
[    37.135] (--) evdev: Chicony USB Wireless HID Receiver: Found scroll wheel(s)
[    37.135] (--) evdev: Chicony USB Wireless HID Receiver: Found relative axes
[    37.135] (--) evdev: Chicony USB Wireless HID Receiver: Found absolute axes
[    37.135] (--) evdev: Chicony USB Wireless HID Receiver: Found absolute multitouch axes
[    37.136] (--) evdev: Chicony USB Wireless HID Receiver: Found x and y absolute axes
[    37.136] (--) evdev: Chicony USB Wireless HID Receiver: Found keys
[    37.136] (II) evdev: Chicony USB Wireless HID Receiver: Forcing relative x/y axes to exist.
[    37.136] (II) evdev: Chicony USB Wireless HID Receiver: Configuring as mouse
[    37.137] (II) evdev: Chicony USB Wireless HID Receiver: Configuring as keyboard
[    37.137] (II) evdev: Chicony USB Wireless HID Receiver: Adding scrollwheel support
[    37.137] (**) evdev: Chicony USB Wireless HID Receiver: YAxisMapping: buttons 4 and 5
[    37.137] (**) evdev: Chicony USB Wireless HID Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    37.137] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:04F2:0420.0002/input/input1/event1"
[    37.138] (II) XINPUT: Adding extended input device "Chicony USB Wireless HID Receiver" (type: KEYBOARD, id 7)
[    37.138] (**) Option "xkb_rules" "evdev"
[    37.138] (**) Option "xkb_model" "pc102"
[    37.138] (**) Option "xkb_layout" "us"
[    37.139] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    37.207] (II) evdev: Chicony USB Wireless HID Receiver: initialized for relative axes.
[    37.207] (WW) evdev: Chicony USB Wireless HID Receiver: ignoring absolute axes.
[    37.209] (**) Chicony USB Wireless HID Receiver: (accel) keeping acceleration scheme 1
[    37.209] (**) Chicony USB Wireless HID Receiver: (accel) acceleration profile 0
[    37.237] (**) Chicony USB Wireless HID Receiver: (accel) acceleration factor: 2.000
[    37.237] (**) Chicony USB Wireless HID Receiver: (accel) acceleration threshold: 4
[    37.276] (II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/js0)
[    37.277] (II) No input driver specified, ignoring this device.
[    37.277] (II) This device may have been added with another device file.
[    37.293] (II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/event2)
[    37.293] (**) Chicony USB Wireless HID Receiver: Applying InputClass "evdev pointer catchall"
[    37.294] (II) Using input driver 'evdev' for 'Chicony USB Wireless HID Receiver'
[    37.294] (**) Chicony USB Wireless HID Receiver: always reports core events
[    37.294] (**) evdev: Chicony USB Wireless HID Receiver: Device: "/dev/input/event2"
[    37.295] (--) evdev: Chicony USB Wireless HID Receiver: Vendor 0x4f2 Product 0x420
[    37.295] (--) evdev: Chicony USB Wireless HID Receiver: Found 3 mouse buttons
[    37.295] (--) evdev: Chicony USB Wireless HID Receiver: Found scroll wheel(s)
[    37.296] (--) evdev: Chicony USB Wireless HID Receiver: Found relative axes
[    37.296] (--) evdev: Chicony USB Wireless HID Receiver: Found x and y relative axes
[    37.296] (II) evdev: Chicony USB Wireless HID Receiver: Configuring as mouse
[    37.296] (II) evdev: Chicony USB Wireless HID Receiver: Adding scrollwheel support
[    37.297] (**) evdev: Chicony USB Wireless HID Receiver: YAxisMapping: buttons 4 and 5
[    37.297] (**) evdev: Chicony USB Wireless HID Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    37.297] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.2/1-1.2:1.2/0003:04F2:0420.0003/input/input2/event2"
[    37.297] (II) XINPUT: Adding extended input device "Chicony USB Wireless HID Receiver" (type: MOUSE, id 8)
[    37.298] (II) evdev: Chicony USB Wireless HID Receiver: initialized for relative axes.
[    37.357] (**) Chicony USB Wireless HID Receiver: (accel) keeping acceleration scheme 1
[    37.358] (**) Chicony USB Wireless HID Receiver: (accel) acceleration profile 0
[    37.358] (**) Chicony USB Wireless HID Receiver: (accel) acceleration factor: 2.000
[    37.358] (**) Chicony USB Wireless HID Receiver: (accel) acceleration threshold: 4
[    37.368] (II) config/udev: Adding input device Chicony USB Wireless HID Receiver (/dev/input/mouse0)
[    37.368] (II) No input driver specified, ignoring this device.
[    37.369] (II) This device may have been added with another device file.
[    37.415] (II) config/udev: Adding input device eGalax Inc. USB TouchController Pen (/dev/input/event3)
[    37.415] (**) eGalax Inc. USB TouchController Pen: Applying InputClass "evdev tablet catchall"
[    37.415] (**) eGalax Inc. USB TouchController Pen: Applying InputClass "eGalax touch class"
[    37.415] (II) LoadModule: "void"
[    37.416] (II) Loading /usr/lib/xorg/modules/input/void_drv.so
[    37.453] (II) Module void: vendor="X.Org Foundation"
[    37.453] 	compiled for 1.15.99.904, module version = 1.4.0
[    37.454] 	Module class: X.Org XInput Driver
[    37.454] 	ABI class: X.Org XInput driver, version 21.0
[    37.454] (II) Using input driver 'void' for 'eGalax Inc. USB TouchController Pen'
[    37.454] (**) eGalax Inc. USB TouchController Pen: always reports core events
[    37.455] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:0EEF:0001.0004/input/input3/event3"
[    37.455] (II) XINPUT: Adding extended input device "eGalax Inc. USB TouchController Pen" (type: Void, id 9)
[    37.457] (**) eGalax Inc. USB TouchController Pen: (accel) keeping acceleration scheme 1
[    37.457] (**) eGalax Inc. USB TouchController Pen: (accel) acceleration profile 0
[    37.458] (**) eGalax Inc. USB TouchController Pen: (accel) acceleration factor: 2.000
[    37.458] (**) eGalax Inc. USB TouchController Pen: (accel) acceleration threshold: 4
[    37.493] (II) config/udev: Adding input device eGalax Inc. USB TouchController Pen (/dev/input/mouse1)
[    37.493] (**) eGalax Inc. USB TouchController Pen: Applying InputClass "eGalax mouse class"
[    37.494] (II) Using input driver 'void' for 'eGalax Inc. USB TouchController Pen'
[    37.494] (**) eGalax Inc. USB TouchController Pen: always reports core events
[    37.494] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:0EEF:0001.0004/input/input3/mouse1"
[    37.495] (II) XINPUT: Adding extended input device "eGalax Inc. USB TouchController Pen" (type: Void, id 10)
[    37.497] (**) eGalax Inc. USB TouchController Pen: (accel) keeping acceleration scheme 1
[    37.497] (**) eGalax Inc. USB TouchController Pen: (accel) acceleration profile 0
[    37.497] (**) eGalax Inc. USB TouchController Pen: (accel) acceleration factor: 2.000
[    37.497] (**) eGalax Inc. USB TouchController Pen: (accel) acceleration threshold: 4
[    37.547] (II) config/udev: Adding input device eGalax Inc. USB TouchController (/dev/input/event4)
[    37.547] (**) eGalax Inc. USB TouchController: Applying InputClass "evdev touchscreen catchall"
[    37.547] (**) eGalax Inc. USB TouchController: Applying InputClass "eGalax touch class"
[    37.548] (II) Using input driver 'void' for 'eGalax Inc. USB TouchController'
[    37.548] (**) eGalax Inc. USB TouchController: always reports core events
[    37.548] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:0EEF:0001.0004/input/input4/event4"
[    37.549] (II) XINPUT: Adding extended input device "eGalax Inc. USB TouchController" (type: Void, id 11)
[    37.581] (**) eGalax Inc. USB TouchController: (accel) keeping acceleration scheme 1
[    37.581] (**) eGalax Inc. USB TouchController: (accel) acceleration profile 0
[    37.581] (**) eGalax Inc. USB TouchController: (accel) acceleration factor: 2.000
[    37.582] (**) eGalax Inc. USB TouchController: (accel) acceleration threshold: 4
[    37.587] (II) config/udev: Adding input device eGalax Inc. USB TouchController (/dev/input/mouse2)
[    37.587] (**) eGalax Inc. USB TouchController: Applying InputClass "eGalax mouse class"
[    37.587] (II) Using input driver 'void' for 'eGalax Inc. USB TouchController'
[    37.588] (**) eGalax Inc. USB TouchController: always reports core events
[    37.588] (**) Option "config_info" "udev:/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:0EEF:0001.0004/input/input4/mouse2"
[    37.588] (II) XINPUT: Adding extended input device "eGalax Inc. USB TouchController" (type: Void, id 12)
[    37.634] (**) eGalax Inc. USB TouchController: (accel) keeping acceleration scheme 1
[    37.635] (**) eGalax Inc. USB TouchController: (accel) acceleration profile 0
[    37.635] (**) eGalax Inc. USB TouchController: (accel) acceleration factor: 2.000
[    37.635] (**) eGalax Inc. USB TouchController: (accel) acceleration threshold: 4
[    51.805] (II) config/udev: Adding input device eGalaxTouch Virtual Device for Single (/dev/input/mouse3)
[    51.805] (**) eGalaxTouch Virtual Device for Single: Applying InputClass "eGalax mouse class"
[    51.806] (II) Using input driver 'void' for 'eGalaxTouch Virtual Device for Single'
[    51.806] (**) eGalaxTouch Virtual Device for Single: always reports core events
[    51.806] (**) Option "config_info" "udev:/sys/devices/virtual/input/input6/mouse3"
[    51.807] (II) XINPUT: Adding extended input device "eGalaxTouch Virtual Device for Single" (type: Void, id 13)
[    51.809] (**) eGalaxTouch Virtual Device for Single: (accel) keeping acceleration scheme 1
[    51.809] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration profile 0
[    51.809] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration factor: 2.000
[    51.809] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration threshold: 4
[    51.821] (II) config/udev: Adding input device eGalaxTouch Virtual Device for Single (/dev/input/js1)
[    51.822] (**) eGalaxTouch Virtual Device for Single: Applying InputClass "eGalax joystick class"
[    51.822] (II) Using input driver 'void' for 'eGalaxTouch Virtual Device for Single'
[    51.822] (**) eGalaxTouch Virtual Device for Single: always reports core events
[    51.823] (**) Option "config_info" "udev:/sys/devices/virtual/input/input6/js1"
[    51.823] (II) XINPUT: Adding extended input device "eGalaxTouch Virtual Device for Single" (type: Void, id 14)
[    51.825] (**) eGalaxTouch Virtual Device for Single: (accel) keeping acceleration scheme 1
[    51.825] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration profile 0
[    51.826] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration factor: 2.000
[    51.826] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration threshold: 4
[    51.828] (II) config/udev: Adding input device eGalaxTouch Virtual Device for Single (/dev/input/event5)
[    51.829] (**) eGalaxTouch Virtual Device for Single: Applying InputClass "evdev pointer catchall"
[    51.829] (**) eGalaxTouch Virtual Device for Single: Applying InputClass "eGalax virtual class"
[    51.829] (II) Using input driver 'evdev' for 'eGalaxTouch Virtual Device for Single'
[    51.830] (**) eGalaxTouch Virtual Device for Single: always reports core events
[    51.831] (**) evdev: eGalaxTouch Virtual Device for Single: Device: "/dev/input/event5"
[    51.831] (--) evdev: eGalaxTouch Virtual Device for Single: Vendor 0xeef Product 0x10
[    51.832] (--) evdev: eGalaxTouch Virtual Device for Single: Found 9 mouse buttons
[    51.832] (--) evdev: eGalaxTouch Virtual Device for Single: Found absolute axes
[    51.832] (--) evdev: eGalaxTouch Virtual Device for Single: Found x and y absolute axes
[    51.832] (--) evdev: eGalaxTouch Virtual Device for Single: Found absolute touchscreen
[    51.832] (II) evdev: eGalaxTouch Virtual Device for Single: Configuring as touchscreen
[    51.833] (**) evdev: eGalaxTouch Virtual Device for Single: YAxisMapping: buttons 4 and 5
[    51.833] (**) evdev: eGalaxTouch Virtual Device for Single: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    51.833] (**) Option "config_info" "udev:/sys/devices/virtual/input/input6/event5"
[    51.834] (II) XINPUT: Adding extended input device "eGalaxTouch Virtual Device for Single" (type: TOUCHSCREEN, id 15)
[    51.834] (II) evdev: eGalaxTouch Virtual Device for Single: initialized for absolute axes.
[    51.836] (**) eGalaxTouch Virtual Device for Single: (accel) keeping acceleration scheme 1
[    51.836] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration profile 0
[    51.837] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration factor: 2.000
[    51.837] (**) eGalaxTouch Virtual Device for Single: (accel) acceleration threshold: 4
