boot Raspberry Pi 3 from a USB mass storage is very slow
Posted: Wed Aug 24, 2016 5:26 pm
by malaz
I used this tutorial to let the Pi boots from usb stick
i used
1- transcend 16gb 3.0 usb
2- sandisk 64gb 3.0 usb
https://www.raspberrypi.org/documentati ... des/msd.md
PI takes a lot of time for responding
Re: boot Raspberry Pi 3 from a USB mass storage is very slo
Posted: Thu Aug 25, 2016 1:32 am
by DougieLawson
How are you measuring it? There's always a delay before the rainbow screen while the hardware decides there's no bootable SDCard and switches to searching the four USB ports for a bootable device.
Posted: Thu Aug 25, 2016 8:09 am
by malaz
DougieLawson wrote:How are you measuring it? There's always a delay before the rainbow screen while the hardware decides there's no bootable SDCard and switches to searching the four USB ports for a bootable device.
i mean while i am working on it, it takes alway a lot of time to do anything , like open folder and even when i use ssh to connect to it
Posted: Thu Aug 25, 2016 8:23 am
by DougieLawson
Have you stumbled on the limited RAM bug? My RPi3B is back on an SDCard because it was only getting 128MB of RAM activated when I boot it from the current BRANCH=next bootcode.bin.
Everything I did caused the system to start swapping and dying through lack of RAM.
Posted: Thu Aug 25, 2016 8:41 am
by fruit-uk
If you want speed then use a USB HDD.
Re:
Posted: Thu Aug 25, 2016 8:45 am
by DougieLawson
fruit-uk wrote:If you want speed then use a USB HDD.
That's completely irrelevant to the discussion here.
viewtopic.php?p=1027850#p1027850
Posted: Thu Aug 25, 2016 11:12 am
by malaz
DougieLawson wrote:Have you stumbled on the limited RAM bug? My RPi3B is back on an SDCard because it was only getting 128MB of RAM activated when I boot it from the current BRANCH=next bootcode.bin.
yeah acutally i boot it from BRANCH=next bootcode.bin, do u have any solution ??
Posted: Thu Aug 25, 2016 11:29 am
by gregeric
Sounds very much like the issue timrowledge reported & investigated here: viewtopic.php?f=63&t=155167&start=75#p1024873
Posted: Thu Aug 25, 2016 11:52 am
by DougieLawson
viewtopic.php?p=1025284#p1025284 is exactly my problem.
