tito-t
Debian Jessie scroll bar width of GUI Windows
Fri Aug 19, 2016 7:39 am
in my Debian Jessie the width (thickness) of the scroll bar of all GUI Windows is far too thin, hard to strike with the mouse cursor - how can one make it thicker, perhaps 2x or 3x as thick?
- Tim
nl3prc
Re: Debian Jessie scroll bar width of GUI Windows
Fri Aug 19, 2016 5:20 pm
Maybe change your screen resolution in config.txt in your boot directory
tito-t
Fri Aug 19, 2016 5:34 pm
no, the resolution is fine, also the window sizes are fine, just the scroll bars are too thin currently.
- Tim
clarks_magic_sac
Fri Dec 29, 2017 3:24 pm
Being an older user I found the bars too thin to hit accurately even with a stylus. I found the fix through changing
sudo nano /home/pi/.themes/PiX/gtk-2.0/gtkrc
Around 20 lines down change the variable 13 in:
GtkRange::slider-width = 13
to something more. 30 is quite big, I have set mine to 20
Then Ctrl X and Y to exit and save.
I also changed
sudo nano /home/pi/.themes/PiX/gtk-3.0/gtk-contained.css
Around 1000 lines down after Notebooks and Tabs section is a section for Scrollbars. You want to alter
-GtkRange-slider-width: 13;
Again I changed mine to 20.
Then Ctrl X and Y to exit and save. Reboot and enjoy
marcosbong
Sun Jan 13, 2019 5:10 pm
Hello.
Anyone knows where this file is located on Stretch?
I changed usr/share/themes/gtk2.0/main.rc line "GtkRange::slider-with and worked with shell but the file managers ( perhaps gtk3.0 because look better? ) keep the scrollbar with same small size 13pix
there are 10 types of people in this world, those who understand binary and those who don´t
marcosbong
Sun Jan 13, 2019 9:38 pm
Hello.
After a pair of reboots mod was applied to every window.
Happy to see that everything is possible in Linux ( I'm a newbie) :D
