When I boot raspberry pi I got following warning:
When I wrote on terminal 192.168.1.1No individual configuration file found for this terminal. Parameters from all.wtc configuration file and default values of parameters will be used. On computer 192.168.2.50 run Start>WTware>Configurator, select terminal MAC B8:27:EB:98:E6:89 and create configuration file Then this message will no longer appear.
Then on terminal window I got:
What I have to do login?Server 192.168.1.1 port 3389: Connection rejected. Make sure that terminal service works on this server. Try to connect using mstsc.exe.
