SSH Not Connecting
Posted: Sat Aug 06, 2016 10:37 pm
by briank1179
When I try to connect to my Raspberry Pi via PuTTy I get "access denied" after entering the password. I know the Pi is connected to the network because I can ping its IP address from the PC with no issues. Even tried connecting SSH through the Pi's terminal and get "Permission denied" after inputting the password. Double checked that I'm using the correct password. I have two Pi's with the same Raspbian image and I'm unable to connect to either via SSH. Restarted the router just to check that possible issue off.
Any suggestions on what to look for would be greatly appreciated.
Thank you
Re: SSH Not Connecting
Posted: Sun Aug 07, 2016 12:43 pm
by nl3prc
maybe you use the wrong username normaly ssh is set to not accept root user tot loggin
you have to use pi as username and i think that the password is raspberry
Posted: Sun Aug 07, 2016 12:58 pm
by nl3prc
Posted: Sun Aug 07, 2016 6:54 pm
by briank1179
Thanks for the information, but I'm a bit confused. Based on information I gleaned from the internet, when I use raspi-config, it allows the user to change the password in "advanced options". If the user changes the password, wouldn't that "new" password be what is needed to login through "SSH". For a test when I tried to Pi's default password, "raspberry", it still gave me "access denied". Using PuTTy shouldn't I be able to access the Pi with it's assigned IP address and it's assigned password?
Based on the forum link submitted I'm not sure I understand. If I use raspi-config, "Advanced Options", to change the password, isn't that new password what is needed for future logins, such as PuTTy?
Again, I really appreciate the help.
Posted: Sun Aug 07, 2016 7:05 pm
by nl3prc
i used passwd to change the password
like this if you are logged in with user pi
sudo passwd root
be aware that you use small print for the user not capital print
Posted: Sun Aug 07, 2016 9:05 pm
by briank1179
Thank you very much!! That helped. It also pointed out a "beginners" mistake I was making in that when it asked for the user's name I was entering the hostname.
Again, I very much appreciate all the your help!!!
Posted: Sun Aug 07, 2016 9:14 pm
by DougieLawson
You can test ssh on the local system.
ssh [email protected] or ssh [email protected].
Posted: Sun Aug 07, 2016 10:38 pm
by rurwin
DougieLawson wrote:You can test ssh on the local system.
Which reminds me of another gotcha. If you just type
ssh machinename
It will try to login with the username that you are logged-in as on the PC that you are typing the command on, which most of the time isn't pi or any other valid account on the RaspPi.
Posted: Mon Sep 05, 2016 1:58 am
by klricks
supra wrote:@briank1179
Try this:
sudo rpi-update.
Please do not suggest rpi-udate to fix random problems. Rpi-update should only be used when told to do so for very specific problems. It should only be used by advanced users who know how to fix any problems that it may cause (or be prepared to re-image the OS).
Posted: Mon Sep 05, 2016 9:25 am
by nl3prc
rpi-update is used to update your kernel and modules and wil have no efect on your inlog users
if you want to update your packages use apt-get update first and than apt-get upgrade
