Still not enough
Ok have you looked at the noob support stuff on the wiki like
http://elinux.org/RPi_Noob_Guide_to_the ... g_an_image
this is not the only option.
If you are using HDMI and the plugs are not in properly or is damaged you would get a green titnted screen but I suspect it is not this it sounds like you are seeing the blank monitor screen.
We need information on the state of the RPi led's what plugs are you using which specific image are you using there are a few nearly all are some version of Debian.
Are you seeing text and typing in startx or are you getting startx automatically
We can help but we need detail. Lots of detail
It looks like we are both having the same empass Vindicator
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek
