Are there any images that fires up an SSH server on boot
Posted: Thu Jul 28, 2016 4:24 pm
by kenneho
Hi.
I don't have any monitors to connect to my new Raspberry Pi at the moment; and were wondering if there are any images that fires up an SSH server with a known username/password on first boot, that I can install on my SD card. This way I won't need a monitor, but just plain old SSH.
Best regards,
kenneho
Re: Are there any images that fires up an SSH server on boot
Posted: Thu Jul 28, 2016 6:21 pm
by fruitoftheloom
kenneho wrote:Hi.
Best regards,
kenneho
Yes Raspbian Jessie installed without using NOOBS:
https://www.raspberrypi.org/documentati ... /README.md
Posted: Thu Jul 28, 2016 6:26 pm
by kenneho
fruitoftheloom wrote:
kenneho wrote:Hi.
Best regards,
kenneho
Excellent! Thanks for the reply. According to https://www.raspberrypi.org/documentati ... sh/unix.md I assume that the SSH server will accept username pi and password raspberry.
Posted: Thu Jul 28, 2016 6:35 pm
by fruitoftheloom
kenneho wrote:Hi.
Best regards,
kenneho
Yes it is the standard user/pass untill you change it.
If you want to see the Desktop GUI use x11vnc: viewtopic.php?f=46&t=154158
Posted: Fri Jul 29, 2016 5:25 pm
by kenneho
fruitoftheloom wrote:.
Thanks for the tips, I'll look into that option.
Posted: Fri Jul 29, 2016 5:43 pm
by mikerr
fruitoftheloom wrote:Yes Raspbian Jessie installed without using NOOBS:
Doesn't NOOBS installed raspbian have that too?
I assumed (dangerously!) that raspbian base config was identical other than the NOOBS partition layout.
Posted: Fri Jul 29, 2016 5:47 pm
by fruitoftheloom
Possibly or the PINN alternative, but why waste SD Card space ?
Posted: Fri Jul 29, 2016 8:03 pm
by kusti8
Yes, but it's more work and more involved to add silent install option and boot it up when you can just write an image , which is guaranteed to work.
