ax25 utils
Posted: Mon Jul 25, 2016 10:23 am
by nl3prc
Hi all i have a big problem when i tied to execut mij script during boot up the kissattach command gets a sigterm and the ax0 and ax1 wil not be started
On mij other system its workin fine ( NOOBS ).
I have tied it strting it like a cron job an in lichtdm and in rc.local
What am i doing wrong
#!/bin/bash
# - AX25 Stack
killall beacon &> /dev/null		# beacon
killall ax25d &> /dev/null		# ax25d
killall ax25rtd &> /dev/null		# ax25rtd
killall ax25ipd &> /dev/null		# ax25ipd
killall netromd &> /dev/null		# netromd
killall mheardd &> /dev/null		# mheardd
killall kissnetd &> /dev/null		# kissnetd
killall kissattach &> /dev/null		# kissattach
killall socat &> /dev/null		# socat
killall aprx &> /dev/null		# aprx
killall fbb &> /dev/null		# fbb
killall xfbbd &> /dev/null		# xfbbd
# - Net/Rom Interfaces
ifconfig nr0 down &> /dev/null		# nr0
ifconfig nr1 down &> /dev/null		# nr1
ifconfig nr2 down &> /dev/null		# nr2
ifconfig nr3 down &> /dev/null		# nr3
ifconfig nr4 down &> /dev/null		# nr4
clear
cp /etc/ax25/ax25ipd.conf.new /etc/ax25/ax25ipd.conf -f
modprobe ax25
modprobe netrom
tmpfile="/tmp/$$.start"
kissnetd -p2 > $tmpfile 2>/dev/null & disown
sleep 2
function attach() {
    read PTS1 PTS2
    echo "Starting ipd on $PTS1 and $PTS2"
    sleep 1
    sed -i "s,device /dev/.*$,device $PTS2," /etc/ax25/ax25ipd.conf
    ax25ipd
    sleep 1
    kissattach $PTS1 axudp 27.137.17.250
tail -n 1 $tmpfile | attach
rm $tmpfile
# start radio poort
kissattach -l /dev/ttyAMA0 1 27.137.17.19
# modprobe netrom
# start netrom poorten en chat server
nrattach -i 27.137.17.251 netrom
nrattach -i 27.137.17.252 fbb
nrattach -i 27.137.17.253 netcht
ax25d
ax25rtd
mheardd -l -n 50
conversd
netromd -i -t 15 &
aprx
fbb
when i start it on the command line in ssh shel it seems to work somewhat but not perfect
Thanks Eddie
Re: ax25 utils
Posted: Thu Jul 28, 2016 7:08 am
by nl3prc
Found it simply put the script in the /etc/init.d directori
and then enter update-rc.d ax25-start.sh defaults 95 5
Now it start up just fine on boot
:D
Re: ax25 utils
Posted: Thu Aug 04, 2016 9:07 pm
by nl3prc
I also want to use Xnet by starting it with qemu-i386 and it starts however in my old linux i used ptyq0 and ttyq0 these ports are no longer availible in the debian jessie on PI what els can i use for this
Re: ax25 utils
Posted: Sun Aug 07, 2016 9:56 am
by nl3prc
I found a way for the psuedo ports
Now i,m having the folowing problem Xnet is not hearing the packets from ax25.
Ax25 is hearing Xnet.
Mij ax2 board is telling me that the both are sending but for some reasen xnet is not hearing the packets
here is my start script and after the reboot i start xnet using qemu-i386 /xnet/linuxsnet
#!/bin/bash
# - AX25 Stack
killall conversd &> /dev/null		# conversd
clear
. /lib/lsb/init-functions
modprobe ax25
modprobe netrom
modprobe mkiss
/usr/local/sbin/kissnetd -p2 > $tmpfile 2>/dev/null & disown
sleep 2
function attach() {
    read PTS1 PTS2
    sleep 1
    /usr/local/sbin/ax25ipd
    sleep 1
    /usr/local/sbin/kissattach $PTS1 axudp 27.137.17.250
rm $tmpfile
# start radio poort
/usr/local/sbin/kissattach /dev/ttyAMA0 1 27.137.17.19
# modprobe netrom
sleep 2
function attach() {
    read PTS1 PTS2
    sleep 1
    sed -i "s,attach sdev0 kiss 1 1 38400 /dev/.*$,attach sdev0 kiss 1 1 38400 $PTS2," /xnet/AUTOEXEC.NET
    cd /xnet
#    qemu-i386 /xnet/linuxsnet
    sleep 1
    /usr/local/sbin/kissattach -m 1580 $PTS1 axip 27.137.17.254
rm $tmpfile
/usr/local/sbin/nrattach -i 27.137.17.251 netrom
/usr/local/sbin/nrattach -i 27.137.17.252 fbb
/usr/local/sbin/nrattach -i 27.137.17.253 netcht
/usr/local/sbin/ax25d
/usr/local/sbin/ax25rtd
/usr/local/sbin/mheardd -l -n 50
conversd
netromd -i -t 15 &
aprx
fbb
Re: ax25 utils
Posted: Sat Aug 13, 2016 12:49 pm
by nl3prc
I found a way to connect ax25-node to xnet using the axudp port
and also startup xnet using screen command
screen -D -m qemu-i386 /xnet/linuxsnet &
be aware that you first cd to the dir ware xnet is installed before you start xnet in my case cd /xnet
otherwise xnet can't find your AUTOEXEC.NET
Re: ax25 utils
Posted: Sat Aug 13, 2016 12:52 pm
by nl3prc
this is now my startup script
#!/bin/bash
# - AX25 Stack
clear
modprobe ax25
modprobe netrom
modprobe mkiss
sleep 2
function attach() {
    read PTS1 PTS2
    sleep 1
    sleep 1
rm $tmpfile
# start radio poort
sleep 4
# tmpfile="/tmp/$$.start"
# /usr/local/sbin/kissnetd -p2 > $tmpfile 2>/dev/null & disown
# sleep 2
# function attach() {
#    read PTS3 PTS4
#    echo "Starting ipd on $PTS3 and $PTS4"
#    sleep 1
#    sed -i "s,attach sdev0 kiss 1 1 9600 /dev/.*$,attach sdev0 kiss 1 1 9600 $PTS3," /xnet/AUTOEXEC.NET
#    cd /xnet
#    sleep 1
#    /usr/local/sbin/kissattach -m 1580 $PTS4 axip 27.137.17.254
# tail -n 1 $tmpfile | attach
# rm $tmpfile
conversd
netromd -i -t 15 &
cd /
cd /xnet
cd /
sleep 4
aprx
fbb
Re: ax25 utils
Posted: Mon Aug 22, 2016 10:54 am
by nl3prc
now i'm fiddling with the the bbs software F6FBB the deamon works like dream but i have some isues with the grafic shell that runs under Xwindows i get a segmetation error
The writer of the program says it's becouse that it is made with obsolete libs
is there any one here that can rewrite this part of the code so it can be used in debian version 8 jessie kernal version 4.4.17+ armv6l
Re: ax25 utils
Posted: Mon Aug 22, 2016 12:36 pm
by nl3prc
as you can see in my previus post he takes up al of cpu time and when i tie to connect to the consol he comes back with a segmentation error
Re: ax25 utils
Posted: Sat Sep 03, 2016 11:34 am
by nl3prc
New problem i have a perl script that is not workin on the raspberry PI B+ with debian jessie
is there somthing i have to change in the script
m_filter
#!/usr/bin/perl
require 5.000;
# FBB Word filter & 7PLUS capture
# Author:  Stewart Wilkinson G0LGS
# Nothing below here should need changing (unless its broken)
$Vers="0.60";
$VDate="20-Mar-2005";
$VData="M_Filter & 7PLUS capture for XFBB 7.01+ (c) 2005 by G0LGS V${Vers} ${VDate}.";
# Read Settings from FBBCONFIG
&ReadFBB_CFG;
# M_FILTER Config File.
$MYCFG="/usr/local/lib/fbb/filter/m_filter.cfg";
# $MYCFG="${CONF}/usr/local/lib/fbb/filter/m_filter.cfg";
$CONF="/usr/local/var/ax25/fbb";
# Wrong number of Parameters ?
if( $#ARGV < 4 ){
   printf STDERR "%s\n", ${VData};
   if( ! -f ${MYCFG} ){
      printf STDERR "WARNING: The Config File %s required by m_filter is missing or unreadable.\n", ${MYCFG};
      printf STDERR "Please correct the problem, as Message Filtering will not work without it.\n";
   exit 0;
# The Parameters
$Mesg=$ARGV[0];
$Type=$ARGV[1];
$From=$ARGV[2];
$To=$ARGV[3];
$RecNo=$ARGV[4];	# Seems to Always be 0 in XFBB.
# Date / Time
($sec,$min,$hour,$mday,$mon,$year,$wday,$yday) = localtime(time);
$SEC=("00".."59")[$sec];
$MIN=("00".."59")[$min];
$HOUR=("00".."23")[$hour];
$MDAY=("00".."31")[$mday];
$MON=("01".."12")[$mon];
$YEAR=("00".."99")[$year % 100];
# Weekly Log File Name
$week=int((${yday}+1) / 7);
$WK=("00".."53")[$week];
$LOGF="${DATA}/log/mftlog.${WK}";
# Some Default Values / Settings
$Subject="(no subject)";
$AUTO7PLUS=1;
$KMAIL=1;
$HMAIL=1;
$LOG=1;
$CAPT="/usr/local/lib/fbb/filter/m_filter.fwd";
# Read our Config file & build our list of search words.
&ReadMY_CFG;
# Don't try to trap our own Messages, as that will cause an endless loop
if( (${From} =~ /^${WHOAMI}$/) && (${To} =~ /^${SYSCALL}$/ )  ){
   exit 0;
# Do we Check Private Messages ?
if( ($Type =~ /p/i) && (!defined($CHECKPRIVATE) || (! $CHECKPRIVATE) ) ){
   exit 0;
$Hold=0;
$Kill=0;
$Found="";
# Check To:
foreach $A (@ToFl) {
   if( ${To} =~ /(${A})/i) {
      $Found="$1";
      $line=${To};
      $Hold=1;
      last;
if( ${Hold} ){
   &DoMsg("Held","To");
   exit 3;
# Check From:
foreach $A (@FmFl) {
   if( ${From} =~ /(${A})/i) {
      $Found="$1";
      $line=${From};
      $Hold=1;
      last;
if( ${Hold} ){
   &DoMsg("Held","From");
   exit 3;
# Subject / Message ID Checking
# Open dirmes.sys
if( open(DIRMES, '<', ${DIRMES} ) ) {
   # Move to the appropriate Record
   # (Always seems = 0 in XFBB).
   seek(DIRMES, ${RecNo} * 194, 0);
   # Read the Record
   if( read( DIRMES, $Rec, 194 ) == 194 ) {
      # Extract Data from Record.
      ($type,$Stat,$Num,$Size,$Date,$Adjbbs,$Route,$Destn,$to,$MID,$Subject,$Resv,$Crdate,$Stdate,$Bbs1,$Bbs2) =
      unpack("Z Z L L L Z7 Z41 Z7 Z7 Z13 Z61 Z16 L L A10 A10", $Rec);
      # Check Message ID
      foreach $M (@Mid) {
         if( ${MID} =~ /(${M})/i) {
            $Found="$1";
            $Hold=1;
            last;
      if( ${Hold} ){
         &DoMsg("Held", "MID");
         exit 3;
      # Check Subject
      foreach $A (@Subj) {
         if( ${Subject} =~ /(${A})/i) {
            $Found="$1";
            $Hold=1;
            last;
      #Check for Kill Words
      foreach $KILL (@Kill) {
         if( ${Subject} =~ /(${KILL})/i) {
            $Found="$1";
            $Kill=1;
            last;
      if(${Kill}){
         &DoMsg("Killed", "Subject");
         exit 1;
      # Check for Hold Words
      foreach $HOLD (@Hold) {
         if( ${Subject} =~ /(${HOLD})/i) {
            $Found="$1";
            $Hold=1;
            last;
      if( ${Hold} ){
         &DoMsg("Held", "Subject");
         exit 3;
   close(DIRMES);
# Open the Message.
if( ! open( MESG, '<', ${Mesg} ) ){
   printf STDERR "Unable to open Message '%s'\n", ${Mesg};
   exit 0;
# Check R: Lines
$Pos = tell(MESG);
while(($line = <MESG>) ){
   chomp($line);
   # Is this an R-Line ?
   if( $line =~ /^R\:\d{6,}\/\d{4}[zZ]{0,1}\s+\d*\@[\:]{0,1}(\S+)/i ) {
      if( !defined(${Via}) ) {
         $Via = $1;
         $Via =~ /^(\w*)\.(.*)$/;
         $via = $1;
      foreach $RL (@Rlin) {
         if( $line =~ /(${RL})/i) {
            $Found="$1";
            $Hold=1;
            last;
      if( $Found ){
         last;
         if( $line =~ /(${KILL})/i) {
            $Found="$1";
            $Kill=1;
            last;
      if( $Found ){
         last;
         if( $line =~ /(${HOLD})/i) {
            $Found="$1";
            $Hold=1;
            last;
      if( $Found ){
         last;
   # No more R:Lines
   }else{
      seek(MESG, $Pos, 0);
      last;
}continue{
   $Pos = tell(MESG);
if( ${Kill} ){
   &DoMsg("Killed", "R-line");
   close(MESG);
   exit 1;
if( ${Hold} ){
   &DoMsg("Held", "R-line");
   close(MESG);
   exit 3;
$Is7plus=0;
# Check for 7PLUS
if( defined(${AUTO7PLUS}) && ${AUTO7PLUS} ) {
   # Check if this the Message has any 7plus
   $Pos = tell(MESG);
   while($line = <MESG>){
      chomp($line);
      # Translate 'non-printable' characters to '.'
      $line =~ s/[\x01-\x1f]/\./g;
      $line =~ s/[\x80-\xff]/\./g;
      # Ignore blank lines
      if( $line =~ /^\s*$/ ){
         next;
      }elsif( $line =~ /\_7\+/ ){
         ${Is7plus} = 1;
         last;
   seek(MESG, ${Pos}, 0);
   # Append to 'mfilter.fwd' file
   if( ${Is7plus} ){
      if( open( CAPT, '>>', ${CAPT} ) ){
         # Message Header
         printf CAPT "SP %s \< %s\n", ${To}, ${From};
         printf CAPT "%s\n", ${Subject};
         # Start at top Of Message
         seek(MESG, 0, 0);
         # Append to file
         print CAPT <MESG>;
         # Reset MESG pointer for rest of checks.
         printf CAPT "/EX\n";
         close(CAPT);
# Check the Message Text
$Pos = tell(MESG);
   chomp($line);
      next;
   # Check for Kill Words
         $Found="$1";
         $Kill=1;
         last;
   if($Found){
      last;
         $Found="$1";
         $Hold=1;
         last;
   if($Found){
      last;
}continue{
   $Pos = tell(MESG);
if(${Kill}){
   &DoMsg("Killed", "Message");
   close(MESG);
   exit 1;
if(${Hold}){
   &DoMsg("Held", "Message");
   close(MESG);
   exit 3;
close(MESG);
# Message Check complete / Tell XFBB to accept message
exit 0;
# Functions used above
# Generate LOG Entry / SYSOP Message
sub DoMsg
   local( $Action ) = $_[0];
   local( $Where ) = $_[1];
   if( defined(${LOG}) && ${LOG} ){
      if( open(LOG, '>>', ${LOGF} ) ) {
         if( defined($via) ) {
            printf LOG "%02d/%02d/%02d %02d:%02d:%02d %s Fm:%s To:%s Via:%s Fnd:%s in %s\n", ${MDAY}, ${MON},${YEAR},${HOUR},${MIN},${SEC}, ${Action}, ${From}, ${To}, ${via}, ${Found}, ${Where};
         }else{
            printf LOG "%02d/%02d/%02d %02d:%02d:%02d %s Fm:%s To:%s Fnd:%s in %s\n", ${MDAY}, ${MON},${YEAR},${HOUR},${MIN},${SEC}, ${Action}, ${From}, ${To}, ${Found}, ${Where};
         close(LOG);
   # Generate SYSOP Message ?
   if(   ( (${Action} =~ /^killed/i) && (defined(${KMAIL}) && ${KMAIL}) )
      || ( (${Action} =~ /^held/i  ) && (defined(${HMAIL}) && ${HMAIL}) )  ) {
      if( open(LOCK, '>', ${LOCK} ) ) {
         printf LOCK "$$";
         if( open(MAIL, '>>', ${MAIL} ) ){
            printf MAIL "SP %s < %s\n", ${SYSCALL}, ${WHOAMI};
            printf MAIL "Message from: %s ${Action}\n\n", ${From};
            printf MAIL "%s\n\n", ${VData};
            if( $Where =~ /^Message/i ){
               printf MAIL "Message From: %s To: Q%sQ - %s because %s contained:\n", ${From}, ${To}, ${Action}, ${Where};
               printf MAIL "the word or phrase 'Q%sQ' in the following line from the message:-\n\n", ${Found};
               printf MAIL "%s\n\n", ${line};
            }elsif( $Where =~ /^Subject/i ){
               printf MAIL "Message From: %s To: Q%sQ - %s because %s contained\n", ${From}, ${To}, ${Action}, ${Where};
               printf MAIL "the word or phrase 'Q%sQ' (Subect: 'Q%sQ')\n\n", ${Found}, ${Subject};
            }else{
               printf MAIL "Message From: %s To: %s - %s because %s contained\n", ${From}, ${To}, ${Action}, ${Where};
               printf MAIL "the word or phrase 'Q%sQ'\n\n", ${Found};
            if( defined(${Via}) ) {
               printf MAIL "\nThe message was forwarded from 'Q%sQ'\n\n", ${Via};
            printf MAIL "/EX\n";
            close(MAIL);
         close(LOCK);
         unlink(${LOCK});
sub IsEnabled
   local($Ret) = 0;
   local($P) = $_[0];
   if( ($P =~ /^0/) || ($P =~ /^n\S*/i) || ($P =~ /^off/i) || ($P =~ /^di\S*/i) ){
         ${Ret}=0;
   }elsif( ($P =~ /^1/) || ($P =~ /^y\S*/i) || ($P =~ /^ok/i) || ($P =~/^on/i) || ($P =~ /^en\S*/i) ){
         ${Ret}=1;
   return ${Ret};
sub ReadFBB_CFG
   # Where is FBB Config File
   $FBBCONF="/usr/local/etc/ax25/fbb/fbb.conf";
   if( defined( $ENV{FBBCONF} ) && "$ENV{FBBCONF}" != "" ){
      $FBBCONF = $ENV{FBBCONF}
   # Read things we need from FBB Config file
   if(! open( FBBCONF, '<', $FBBCONF) ) {
      printf STDERR "Unable to open '%s'\n", ${FBBCONF};
      exit 1;
   while($line = <FBBCONF>) {
      chomp($line);
      if( $line =~ /^\s*\#/) {
         next;
      }elsif( $line =~ /^\s*$/) {
         next;
      }else{
         $line =~ /^\s*(\S*)\s*\=\s*(.*)$/;
         $item = $1;
         $value = $2;
         if( $item =~ /^callsign/ ){
            $value =~ /^(\w*)\.(.*)$/;
            $BBSCALL = $1;
            $BBSHR = $2;
            $WHOAMI = $BBSCALL;
         }elsif( $item =~ /^data/ ){
            $value =~ /^(\S*)$/;
            $DATA = $1;
            $DIRMES="${DATA}/dirmes.sys";
         }elsif( $item =~ /^conf/ ){
            $CONF = $1;
         }elsif( $item =~ /^name/ ){
            $NAME = $1;
         }elsif( $item =~ /^syso/ ){
            $SYSCALL = $1;
         }elsif( $item =~ /^impo/ ){
            $value =~ /^([^\.]\S*)\.(\S*)$/;
            $MAIL = "$1.$2";
            $LOCK = "$1.lck";
   close(FBBCONF);
sub ReadMY_CFG
   if( ! open( MYCFG, '<', ${MYCFG} ) ) {
      if( ! -f "${CONF}/m_filter.warn" ){
            printf LOCK "$$";
               printf MAIL "WARNING: M_Filter Config Error\n\n";
               printf MAIL "The Config File %s required by m_filter is missing or unreadable.\n", ${MYCFG};
               printf MAIL "Please correct the problem, as Message Filtering will not work without it.\n";
               close(MAIL);
            close(LOCK);
            unlink(${LOCK});
         if( open(WRN, '>', "${CONF}/m_filter.warn" ) ){
            print WRN "m_filter is not correctly configured !";
            close WRN;
      exit 0;
   if( -f "${CONF}/m_filter.warn" ){
      unlink( "${CONF}/m_filter.warn" );
   $Subj=0;
   $Rlin=0;
   $ToFl=0;
   $FmFl=0;
   $Hold=0;
   $Kill=0;
   $Mid=0;
   while(<MYCFG>) {
      chomp;
      # Comments
      if( /^\s*\;/ ) {
         next;
      }elsif( /^\s*\#\S*/ ){
         next;
      # Blank Lines
      }elsif( /^\s*$/ ) {
         next;
      # Generate Filter message for Held Messages ?
      }elsif( /^\s*\!\s*MAIL\s*\=\s*(\S*)/ ){
         $HMAIL = &IsEnabled($1);
         next;
      # Generate Filter message for Killed Messages ?
      }elsif( /^\s*\!\s*KMAIL\s*\=\s*(\S*)/ ){
         $KMAIL = &IsEnabled($1);
         next;
      # 7PLUS Capture ?
      }elsif( /^\s*\!\s*AUTO7PLUS\s*\=\s*(\S*)/ ){
         $AUTO7PLUS = &IsEnabled($1);
         next;
      # CHECK PRIVATE Messages ?
      }elsif( /^\s*\!\s*CHECKPRIVATE\s*\=\s*(\S*)/ ){
         $CHECKPRIVATE = &IsEnabled($1);
         next;
      # FBB m_filter.fwd (for 7plus AutoCapture)
      }elsif( /^\s*\!\s*7PLUS\s*\=\s*(\S*)/ ){
         $CAPT="$1";
      # FILTER Messages From:
      }elsif( /^\s*\!\s*WHOAMI\s*\=\s*(\S*)/ ){
         $WHOAMI = $1;
      # Logging ?
      }elsif( /^\s*\!\s*LOG\s*\=\s*(\S*)/ ){
         $LOG = &IsEnabled($1);
         next;
      # Kill Words / Phrases
      }elsif( /^\s*\!\sKILL/i ) {
         $Subj=0;
         $Rlin=0;
         $ToFl=0;
         $FmFl=0;
         $Hold=0;
         $Kill=1;
         $Mid=0;
      # Hold Words / Phrases
      }elsif( /^\s*\!\sHOLD/i ) {
         $Subj=0;
         $Rlin=0;
         $ToFl=0;
         $FmFl=0;
         $Hold=1;
         $Kill=0;
         $Mid=0;
      # R:Line Words / Phrases
      }elsif( /^\s*\!\sRLINE/i ) {
         $Subj=0;
         $Rlin=1;
         $ToFl=0;
         $FmFl=0;
         $Hold=0;
         $Kill=0;
         $Mid=0;
      # To Calls to Check
      }elsif( /^\s*\!\sTO/i ) {
         $Subj=0;
         $Rlin=0;
         $ToFl=1;
         $FmFl=0;
         $Hold=0;
         $Kill=0;
         $Mid=0;
      # From Calls to Check
      }elsif( /^\s*\!\sFROM/i ) {
         $Subj=0;
         $Rlin=0;
         $ToFl=0;
         $FmFl=1;
         $Hold=0;
         $Kill=0;
         $Mid=0;
      # Additional Subject Words
      }elsif( /^\s*\!\sSUBJECT/i ) {
         $Subj=1;
         $Rlin=0;
         $ToFl=0;
         $FmFl=0;
         $Hold=0;
         $Kill=0;
         $Mid=0;
      # Message ID's
      }elsif( /^\s*\!\sMID/i ) {
         $Subj=0;
         $Rlin=0;
         $ToFl=0;
         $FmFl=0;
         $Hold=0;
         $Kill=0;
         $Mid=1;
      # Ignore unknown config lines.
      }elsif( /^\s*\!\S*/i ) {
         next;
      }else{
         # Format Word / Phrase for PERL Regular Expression Handling.
         # Add '\' escapes to some special characters
         s/([\#\!\@\:\[\]\\\/\.\*\?])/\\$1/g;
         # Change any ' ' to '\s{1}' (match exactly 1 space)
         s/\ /\\s{1}/g;
         # Insert Temporary Leading Space (so that some of the remaining
         # checks work at the begining of the line)
         $_ = " " . $_;
         # Change '+', but not '%+' to '\b' (word boundary)
         s/([^%])\+/$1\\b/gx;
         # Change '%+' to '\+'
         s/%\+/\\+/g;
         # Change '_', but not '%_' to '\s+' (one or more spaces)
         s/([^%])_/$1\\s+/gx;
         # Change '%_' to '_'
         s/%_/_/g;
         # Change '%d' to '\d'	(decimal number)
         s/%d/\\d/gi;
         # Change '%s' to '\S'	(non-space char)
         s/%s/\\S/gi;
         # Remove Leading Space
         s/^\ //;
         if($Subj){
            push( @Subj, $_ );
         }elsif($Rlin){
            push( @Rlin, $_ );
         }elsif($ToFl){
            push( @ToFl, $_ );
         }elsif($FmFl){
            push( @FmFl, $_ );
         }elsif($Hold){
            push( @Hold, $_ );
         }elsif($Kill){
            push( @Kill, $_ );
         }elsif($Mid){
            push( @Mid, $_ );
   close(MYCFG);
and here is my m_filter.cfg
; This is the config file for G0LGS's M_FILTER for Linux XFBB.
; Blank lines are ignored as are lines starting with a ';' or '#'
; Config Options (yes/ok/on/1/en = Enable, no/off/0/di = Disable);
! MAIL = no		; Tell Sysop about Held Mail (Default = yes)
! KMAIL = no		; Tell Sysop about Killed Mail (Default = yes)
! CHECKPRIVATE = yes	; Do we Check Private Messages ?
! AUTO7PLUS = yes	; Do we Auto Collect 7plus (default = yes)
! 7PLUS = /usr/local/lib/fbb/filter/m_filter.fwd
                        ; Where to place 7plus Extracts.
                        ; Default = /usr/local/lib/fbb/filter/m_filter.fwd
! WHOAMI = NL4PRC       ; From 'Callsign' for FILTER Messages
                        ; Default = FILTER  (V0.5x)
                        ;           BBSCall (from V0.60)
! LOG = yes             ; Enable Logging (default = yes)
; Lines beyond this point which start with '!' are important
; and MUST NOT be removed or changed.
; Each line should be a word (or partial word) or even a phrase to
; look for (Not case sensitive).
; Use '_' to match one or more spaces in middle of a word or phrase.
; ( use '%_' to match a real '_' )
; Use a space (' ') where you want to match exactly one space.
; you can also use:
; +word		match at begining of word
; word+		match at end of word
; +word+	match whole word only
; (use '%+' to match a real '+')
; These should also work:
; ^word		match ONLY at start of a line.
; word$		match ONLY at end of a line.
; These are available from V0.52 :
; %d		decimal number
; %d{m}		decimal number exactly m digits long
; %d{m,}	decimal number m or more digits long
; %d{m,n}	decimal number between m & n digits long
; %s		any string (except space)
; %s{m}		any string exactly m chars long
; %s{m,}	any string m or more chars long
; %s{m,n}	any string between m & n chars long
; Kill These on sight !!
! KILL
; Hold These for review
! HOLD
ABUSE+
abuse+
abuse!+
ABUSE!+
+Doorgestuurd bericht+
+login password+
; Additional Hold Words for Subject
; The Subject are checked for HOLD/KILL words plus anything listed here:
! SUBJECT
Filer's_Files
; Hold on From: Field
! FROM
; Examples:
; Any Italian Callsign
;I%s{0,1}%d{1,2}%s{1,3}
; Any German Callsign
;D%s{0,1}%d{1,2}%s{1,3}
; UK Calligns
;G%s{0,1}%d{1}%s{1-3}
;M%s{0,1}%d{1}%s{1-3}
;2%s{1}%d{1}%s{1-3}
; Hold on To: Field
! TO
; Hold on R: line
; (R: Lines gets checked for HOLD/KILL words plus anything listed here).
! RLINE
; Old messages
^R:99%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:00%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:01%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:02%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:03%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
; non-Y2K R-lines
^R:101%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:102%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:103%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:104%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
^R:105%d{4}/%d{4}%s{0,1}[email protected]:%s{1,}
; CB Systems:
; NL3DHR.NH.NLD.EU
; EA8EE has been sending Internet newsgroups, so check all messages
; passing through his system.
EA8EE
; Hold on Message ID - Requires V0.60
! MID
%d{1,6}%_XXXXXX
%d{1,6}-XXXXXX
Re: ax25 utils
Posted: Sat Sep 03, 2016 2:50 pm
by scruss
Unfortunately, I'm not surprised you're getting no hits to your questions on AX25. Packet radio has almost disappeared over the last decade. Even APRS has big holes in FM repeater coverage in North American cities.
You might be able to built xfbb for yourself with if you install the lesstif2-dev and libax25-dev packages. As for your Perl script, what error messages does it give? It looks like the sort of horrid non-structured code I was debugging (and sadly, creating more of) in the late 1990s. It looks like there are some hard-coded paths that have been changed by a particular user all over the script, and some of the routines look like they'd fail quietly if they couldn't read or write the file.
73 de VA3PID
Re: ax25 utils
Posted: Sat Sep 03, 2016 7:15 pm
by nl3prc
no errors when starting it by hand
[email protected]:/usr/local/lib/fbb/filter# ./m_filter
M_Filter & 7PLUS capture for XFBB 7.01+ (c) 2005 by G0LGS V0.60 20-Mar-2005.
the 7plus capture works but the rest of filtering for keywords in the mails is not
Re: ax25 utils
Posted: Sat Sep 03, 2016 7:33 pm
by scruss
It opens a log somewhere; anything in that?
Re: ax25 utils
Posted: Sun Sep 04, 2016 9:15 am
by nl3prc
yess there is one it say's that it is filtering but the messages ar not put on held in fbb
Maybe its not a m_filter problem but a fbb fault
03/09/16 13:40:02 Held Fm:EFER18 To:FUNK Via:NL3PRC Fnd:login password in Message
03/09/16 21:11:36 Held Fm:CB2PRC To:TEST Fnd:abuse in Subject
03/09/16 21:20:32 Held Fm:CB2PRC To:TEST Fnd:abuse in Subject
