456mb
Relay
Sat Jul 23, 2016 1:58 am
Hi i new here, i have a simple question
i have a raspberry 3B and a relay
only i want test on/off the relay in the raspberry any simple code for testing??? i find in google but i find only for 8 channels or more of three pins
thanks
pcmanbob
Re: Relay
Sun Jul 24, 2016 12:04 pm
You will need to provide much more info on the relay board you want to use the picture gives no info.
A link to a data sheet or other specification sheet is what will be needed.
drgeoff
Re: Relay
Sun Jul 24, 2016 6:38 pm
It is a 5 volt relay. The board has a transistor Q1 to the left of the relay. There is resistor R1 (150 ohms?), probably between the transistor base and the input pin labelled S.
A diode, probably across the relay coil. And an LED, but no sign of a series resistor for it.
gordon77
Re: Relay
Sun Jul 24, 2016 7:02 pm
This site Q&A says it will only work with 5v...
http://www.cytron.com.my/p-bb-relay-5v-01
drgeoff
Re: Relay
Sun Jul 24, 2016 7:21 pm
That site also says the control input level is TTL. That is 2.4 volts.
gordon77
Re: Relay
Sun Jul 24, 2016 8:10 pm
If you follow this link it says the signal input min'n 3.3v max 5v so might work. + supply is 5v.
https://www.parallax.com/product/27115
456mb
Re: Relay
Tue Jul 26, 2016 6:59 am
i buy here https://www.amazon.com/gp/product/B00TO ... UTF8&psc=1
is probability connect direct ? relay -> raspberry ??
5V => + (relay)
GROUND => - (relay)
GPIO => S (relay)
is correct ??
https://youtu.be/3u45htuQeag?t=24s
thanks for your time and help
