Bluetooth audio reciever not work
Posted: Sat Jul 16, 2016 12:17 pm
by Vairetz
Hi, I install raspbian and I'd like streaming music with bluetooth from my smartphone. I install bluez, blueman (2.0.3) and pulseaudio-module-bluetooth and now on device configuration (in bluman) I see the audio source option but when I try to connect my phone It fails.. the error message is: bluema.bluez.errors.DBusFailedError: No such file or directory. What I was wrong? How can I fix it?
Re: Bluetooth audio reciever not work
Posted: Sat Jul 16, 2016 12:24 pm
by fruitoftheloom
Vairetz wrote:Hi, I install raspbian and I'd like streaming music with bluetooth from my smartphone. I install bluez, blueman (2.0.3) and pulseaudio-module-bluetooth and now on device configuration (in bluman) I see the audio source option but when I try to connect my phone It fails.. the error message is: bluema.bluez.errors.DBusFailedError: No such file or directory. What I was wrong? How can I fix it?
What version of Raspbian ? Wheezy or Jessie ?
Posted: Fri Jul 22, 2016 11:15 am
by Vairetz
It's Raspbian Jessie 2016
Posted: Fri Jul 22, 2016 1:24 pm
by rloftus
Did you check the time zone on your Pi? I found that mine wouldn't connect to any network other than wifi until after I adjusted my clock so it was set for the correct time zone.
Posted: Fri Jul 22, 2016 3:21 pm
by fruitoftheloom
Vairetz wrote:It's Raspbian Jessie 2016
If you had fully updated Jessie, then BlueTooth support is enabled by default, FYI blueman can be buggy:
https://www.raspberrypi.org/blog/anothe ... e-raspbian
Posted: Wed Jul 27, 2016 3:11 pm
by Vairetz
My problem is that the smartphone does not connect as the audio source , I can not understand why. I try to use Ubuntu mate for raspberry and I hadn't problem, with raspbian bluetooth audio source not work
Posted: Wed Jul 27, 2016 3:40 pm
by Douglas6
1. Is the Bluetooth adapter up and running? Check it with
2. Is the Bluetooth daemon running? Check with
3. Is PulseAudio installed? Install it with
sudo apt-get install pulseaudio pulseaudio-module-bluetooth
4. Is the phone paired and trusted? Use bluetoothctl. If needed remove and re-pair.
This tutorial will work to make the Pi into a Bluetooth A2DP sink:
https://github.com/davidedg/NAS-mod-con ... Audio5.txt
Posted: Wed Jul 27, 2016 6:37 pm
by Vairetz
I solved the problem, pulseaudio was not automatically launched.
With the comand: /usr/bin/pulseaudio --start the problem was solved..
Now how do I launch it automatically?
Posted: Wed Jul 27, 2016 6:48 pm
by Douglas6
The link I posted in my previous post explains how to create and enable a system unit to launch PulseAudio at boot. Make sure root is in the proper groups as well.
