P C Prabhu Kumar
Firewall security for Raspi
Thu Jun 30, 2016 10:07 am
Hi
will Raspi supports any physical or logical Firewalls ? Please let me know any other security measures for Raspi?
java
Re: Firewall security for Raspi
Thu Jun 30, 2016 12:27 pm
Raspbian, and I suspect that all other Linux distributions that run on the RPi boards, have iptables for firewalling. Numerous frontends exist for easing the setup for iptables.
pi-anazazi
Thu Jun 30, 2016 1:26 pm
...here is some advice :
http://www.heystephenwood.com/2013/06/s ... ry-pi.html
PS: Exposing port 22 of a raspi to the rest of the world is in my opinion one of the LESS clever ideas in this world.
Kind regards
anazazi
Romonga
Thu Jun 30, 2016 2:10 pm
pi-anazazi wrote:...here is some advice :
Yes, it is. This is why if it needs to be open you should use a Key. Or at the very least only allow access by MAC address.
You can run, but you will only die tired.
mfa298
Thu Jun 30, 2016 3:49 pm
Romonga wrote:
pi-anazazi wrote: PS: Exposing port 22 of a raspi to the rest of the world is in my opinion one of the LESS clever ideas in this world.
MAC addresses are only visible on the local network. If I connected to your Pi the only MAC address it would see is the MAC address of your router. You can however have IP ranges on the firewall rules so you can allow access from trusted IP ranges.
A strong password or preferably key only access should be used for SSH is it's open, it's often also preferable to move the SSH port away from port 22. Moving the SSH port doesn't necessarily make you any more secure, but it does stop all the password guessing attempts that fill up the logs.
Thu Jun 30, 2016 9:12 pm
I think you need to qualify that with "Exposing port 22 without applying some exceedingly strong security and intrusion detection, is one of the LESS clever ideas in this World".
FTP and plain old telnet have a much higher risk than SSH.
pi-anazazi
Fri Jul 01, 2016 7:16 am
For sure you will always find somefink WORSE, but if I have a look at my firewall/IDS logs port 22 (and standard user pi) is REALLY not a good idea.
Kind regards
anazazi
Fri Jul 01, 2016 7:36 am
pi-anazazi wrote:For sure you will always find somefink WORSE, but if I have a look at my firewall/IDS logs port 22 (and standard user pi) is REALLY not a good idea.
User pi with its password left as raspberry is an enormous security exposure.
SSH with passwords disallowed is relatively safe.
