Adarsh Singh
Inputs to GPIO
Sat Jun 25, 2016 2:31 pm
Hey,
I'm very new to raspberry pi and I am not able to understand :?: what is the difference between
GPIO.high and
GPIL.low
Thanks for any help.
bytesoup
Re: Inputs to GPIO
Sat Jun 25, 2016 2:33 pm
Hi Adarsh,
From this page : https://www.raspberrypi.org/documentation/usage/gpio/
...When the pin is HIGH it outputs 3.3 volts (3v3); when the pin is LOW it is off....
Adarsh Singh
Re: Inputs to GPIO
Sat Jun 25, 2016 2:50 pm
bytesoup wrote:Hi Adarsh,
I know that this is for the output, But does this also apply on inputs.
eg
While gpio2.high
print ('button pressed')?
joan
Re: Inputs to GPIO
Sat Jun 25, 2016 2:59 pm
A GPIO in mode INPUT will
  • read 1 (high) if 3V3 is connected
  • read 0 (low) if 0V is connected
Adarsh Singh
Re: Inputs to GPIO
Sun Jun 26, 2016 6:17 am
joan wrote:A GPIO in mode INPUT will
ok now i get it
Burngate
Re: Inputs to GPIO
Sun Jun 26, 2016 3:53 pm
bytesoup wrote:From this page : https://www.raspberrypi.org/documentation/usage/gpio/
... When the pin is HIGH it outputs 3.3 volts (3v3); when the pin is LOW it is off ...
I'm not sure I agree with the second half of that ...
... When the GPIO pin is LOW it outputs 0v - so if you connect a LED plus resistor from a 3v3 pin to the GPIO, the LED will light
- if it were off, as in a switch is off, no current could flow and the LED wouldn't light.
Possibly nit-picking, but also possibly giving the reader the wrong idea from the start.
gordon77
Re: Inputs to GPIO
Sun Jun 26, 2016 4:23 pm
Agreed, LOW means connected to gnd.
Adarsh Singh
Re: Inputs to GPIO
Mon Jun 27, 2016 9:21 am
Thanks for all your help.
I have now understood this :)
