murgrabia
music
Thu Jun 23, 2016 6:08 pm
what should i do to play music on my raspberry? can i use gpio pins , mini-jack or hdmi?
Re: music
Thu Jun 23, 2016 8:18 pm
HDMI is easiest.
3.5mm is a passable alternative.
GPIO is impossible without extra hardware to emulate the 3.5mm jack. (It uses a pair of GPIOs)
USB audio or a special audio HAT are your other options.
murgrabia
Re: music
Thu Jun 23, 2016 8:23 pm
Thanks for answer, can you explain me in details how to emulate 3.5 jack using GPIO, i want to play mp3 music file. I have RPI 2B
Re: music
Thu Jun 23, 2016 9:49 pm
See here: https://learn.adafruit.com/adding-basic ... o/overview emulating the hardware is the only way to get sound on a Zero.
HawaiianPi
Re: music
Fri Jun 24, 2016 1:33 am
murgrabia wrote:Thanks for answer, can you explain me in details how to emulate 3.5 jack using GPIO, i want to play mp3 music file. I have RPI 2B
If you have a Pi2B, why not just use the actual 3.5mm jack?
murgrabia
Re: music
Fri Jun 24, 2016 6:37 pm
when i put headphones into mini-jack i hear strange noise and cant listen to music, its brand new
HawaiianPi
Re: music
Fri Jun 24, 2016 7:07 pm
murgrabia wrote:when i put headphones into mini-jack i hear strange noise and cant listen to music, its brand new
Just tried headphones in my Pi3, and while it's not audiophile quality, it's not awful either.
What kind of strange noise are you hearing? And have you tried cleaning the plug on your headphones?
murgrabia
Re: music
Fri Jun 24, 2016 7:43 pm
similar to the sound of the sea, but i can also hear the music but not very loudly
HawaiianPi
Re: music
Fri Jun 24, 2016 7:54 pm
Try cleaning your headphone's plug, and make sure it is inserted into the jack properly.
java
Re: music
Sat Jun 25, 2016 7:53 am
Try a mini headphone jack to RCA connector cable and play your music back thru a normal amp - then you should know whether your headphones are at fault - most likely - or the fault lies with the RPi. If the RPi there are somethings that can influence the audio produced.
Both my RPi B and RPi 2, produce decent sound out of the Headphone jack. For great sound a Asus U3 Xonar USB or Iqaudio Pi - Dac +, are used. Your headphones might just need a headphone amp to drive them properly - way too many variables involved.
