Im struggling with this problem. I'd like to boot my Pi into the command line, (no startx). How can I simply open and display an image on the screen from the command line. Like I can display a video using omxplayer without, the GUI / XServer running.
Re: View Image without XServer
Hi dudewheresmycode,
still wating for my pi, so I tested all this on a standard Debian. But maybe it works for you , too.
You could use "fbi" (frame buffer image viewer). You simply install it by executing Afterwards, you can view images in terminal by typing
If it gives you an error like "open /dev/fb0: No such file or directory" it means you first have to activate framebuffer output. The following steps may require root privileges (sudo):
( DISCLAIMER: If you wreck your grub it can destroy your system. Watch your step! )
- open "/etc/default/grub" in your editor of choice.
- locate the line that says "GRUB_GFXMODE=640x480"
- uncomment it and enter the screen resolution you want
- save and exit
- open " /etc/grub.d/00_header "
- go to the line that says "set gfxmode={$GRUB_GFXMODE}"
- insert "set gfxpayload=keep" below it
- save and exit
- execute "update-grub"
- reboot
Now, if you try again to view the image with fbi it should work.
Regards
apt-get install fbi
fbi <imagename>
- save and exit
- save and exit
- reboot
Regards
"If people read the FAQs the Qs wouldn't be A F, would they?"
Hey that works pretty well.
Although, doesn't suit my need exactly, as I can't seem to run it from a SSH console or from a script in node.js. Only from the pi console itself.
I get the error:
Any ideas?
I get the error:
Error: Command failed: using "DejaVu Sans Mono-16", pixelsize=16.67 file=/usr/share/fonts/truetype/ttf-dejavu/DejaVuSansMono.ttf
ioctl VT_GETSTATE: Invalid argument (not a linux console?)
stdout: stderr: using "DejaVu Sans Mono-16", pixelsize=16.67 file=/usr/share/fonts/truetype/ttf-dejavu/DejaVuSansMono.ttf
from the fbi manpage:
I could only think of three solutions:
- looking fo another image viewer that can handle pseudo tty
- transcribe your JS script to a shell script
- make your script execute fbi in a tty somehow (not even sure this is possible)
I will have a look at one or two of the options. Maybe someone else comes through with a solution in the meantime.
Regards
I do not know very much about Javascript, but as far as I know it runs in its own shell and not directly from tty. So we semm out of luck here. If you want to stick to Javascript, fbi apparently does not do the trickfbi also needs access to the linux console (i.e. /dev/ttyN) for sane console switch handling. That is obviously no problem for console logins, but any kind of a pseudo tty (xterm, ssh, screen, ...) will not work.
Regards
I should note that `fbi` has been replaced by `fim` which seems to be an updated version of `fbi`.
http://manpages.ubuntu.com/manpages/luc ... fim.1.html
I've found this works over SSH / external scripts. So problem (almost) solved.
I'm looking for a way to boot my Raspberry into CLI (not loading X) and displaying a pretty image on the screen after boot, rather then a login prompt and CLI text. When I display an image to the framebuffer for output, it doesn't remain on the screen. It gets drawn over by the CLI cursor flashing or output from the CLI.
Still tinkering, I'll post progress here as I go.
Thanks for pointing me in the right direction!
any luck with that pretty picture?
Hidudewheresmycode wrote:Hey that works pretty well.
I get the error:Any ideas?Code: Select all
Error: Command failed: using "DejaVu Sans Mono-16", pixelsize=16.67 file=/usr/share/fonts/truetype/ttf-dejavu/DejaVuSansMono.ttf ioctl VT_GETSTATE: Invalid argument (not a linux console?) stdout: stderr: using "DejaVu Sans Mono-16", pixelsize=16.67 file=/usr/share/fonts/truetype/ttf-dejavu/DejaVuSansMono.ttf ioctl VT_GETSTATE: Invalid argument (not a linux console?)
I had the same issue over SSH. Since I wanted to use FBI instead of FIM, the solution was thus:
make a shell script on the pi with the following:
filename IMAGE.sh
#bin/bash
then you can run it from SSH execution using:
SSH2.execCommand("nohup ./IMAGE.sh > /dev/null 2>&1")
I am using an android tablet to send commands to the pi. Its working fine for me.
