DnArturo
Auto type "vncserver :1" on reboot
Wed Jun 15, 2016 1:35 pm
Hello Raspberry Pi community!
Have some limited success on my pi so far but my next project is to automatically enable the VNC on the pi. Currently when I boot it up I have to go to putty, log in, type vncserver :1, then go to the VNC program and re-log in from there. Both Google and Youtube came up short in giving me a straight answer.
How does one make the pi perform the "vncserver :1" command on boot up so I don't have to log on through putty?
Thanks much!
Art
Romonga
Re: Auto type "vncserver :1" on reboot
Wed Jun 15, 2016 3:13 pm
You can run, but you will only die tired.
pi-anazazi
Thu Jun 16, 2016 1:27 pm
Hint: Good chance that
"sudo ipconfig"
in the first step of the Instructable should read
"sudo raspiconfig"
....I guess ;-)
Kind regards
anazazi
penguintutor
Thu Jun 16, 2016 3:47 pm
As an alternative I've written a guide to starting tightvnc at startup, it uses a systemd startup file, which is the same way that other services are started on the Raspberry Pi.
http://www.penguintutor.com/linux/tightvnc
DnArturo
Tue Jun 28, 2016 5:31 pm
SonOfAMotherlessGoat wrote:http://simplesi.net/auto-install-x11vnc/
This appears to install VNC but does not execute the command automatically.
DnArturo
Tue Jun 28, 2016 6:42 pm
This works and is the best answer for 6/28/2016.
Recap:
1. sudo Raspi-config > option 3 (boot options) > B4 (Desktop login with auto sign-on)
2. cd /home/pi/.config
3. sudo mkdir autostart
4. cd autostart
5. sudo nano tightvnc.desktop
[Desktop Entry]
Type=application
Name=TightVNC
Exec=vncserver :1
StartupNotify=false
6. Ctrl+x to save > "y" > sudo reboot
Then forget putty and go straight to VNC Server :)
Art
