fan
Easiest programming language for controlling gpio pins
Sun Jun 12, 2016 12:10 pm
I got a pi and I want to start having fun with gpio pins, but there is one problem I am so lost in all of these programming languages. I know a little of c (printf,scanf,do,while,if....) but I am so lost righ now. Can you guys link me some tutorial and give me some tips. Basically all I want is to control (power) some LED diodes , transistor and releys with that program. My goal is to make a program that runs by itself (turning gpio pins on every few hours).
joan
Re: Easiest programming language for controlling gpio pins
Sun Jun 12, 2016 1:12 pm
http://elinux.org/RPi_GPIO_Code_Samples
My feeling is that a Python based solution may be your easiest.
flatmax
Sun Jun 12, 2016 1:38 pm
The absolute simplest way to alter gpio pins ... at least for first exploration is just in a terminal ... like so ... will send 1 and 0 to gpio11 ...
open a terminal and change to super user with sudo -i and then :
echo 11 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio11/direction
echo 1 > /sys/class/gpio/gpio11/value
echo 0 > /sys/class/gpio/gpio11/value
Matt
Discuss hearing, acoustics, audio injector products, - https://lists.audioinjector.net/mailman/listinfo/people
Sound card for the Raspberry Pi with inbuilt microphone : www.audioinjector.net
Audio Inector Octo multitrack GPIO sound card
derekiwi
Sun Jun 12, 2016 2:34 pm
Hi Flatmax,
I am also a total newbie to Pi, Linux etc. I started with RPi.GPIO, and it is easy to use and learn. I was going to attach a sample for you but the forum does not let me, so pasted in below.. Currently having a look at wiringPi - seems just as easy and documentation is better. But I would start with RPi.GPIO.
RPi.GPIO should be installed on your Raspberry already if you are using Rasbian and have the latest version. Otherwise ....
https://sourceforge.net/p/raspberry-gpi ... i/install/ (note that you do not need Mercurial)
http://wiringpi.com/
Cheers, Derek
#!/usr/bin/env python
import time
import sys
import RPi.GPIO as GPIO
# gpio may still open from last session if abnormally exited
GPIO.setwarnings(False)
# set to defining by header pins, instead of BCM
GPIO.setmode(GPIO.BOARD)
print ("System Setup.")
print (GPIO.RPI_INFO)
# set up gpio ehader pin 35 (BCM and GPIO 19) as output
TestPin = 35
GPIO.setup (TestPin, GPIO.OUT)
print ("Main loop start....")
# Main loop
try:
while True:
# toggle the pin each loop
GPIO.output(TestPin, True)
time.sleep(0.25)
GPIO.output(TestPin, False)
time.sleep(0.25)
# press Ctl-c to exit
except KeyboardInterrupt:
GPIO.cleanup()
print ("Cleaned up. Bye.")
sys.exit(0)
kusti8
Sun Jun 12, 2016 2:35 pm
derekiwi wrote:Hi Flatmax,
Cheers, Derek
import time
import sys
TestPin = 35
# Main loop
try:
    while True:
        time.sleep(0.25)
        time.sleep(0.25)
    GPIO.cleanup()
    sys.exit(0)
Put your code in code brackets, so that indentation is kept. Fixed for you.
timrowledge
Sun Jun 12, 2016 3:16 pm
Scratch. It's already loaded, it has examples, there is documentation.
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
recantha2
Contact: Website Facebook Twitter
Sun Jun 12, 2016 7:14 pm
Python, using the GPIO Zero library would seem to be appropriate.
from gpiozero import LED
red = LED(4)
red.on()
Michael Horne - @recantha
Raspberry Pi blog - http://www.recantha.co.uk/blog
Cambridge Raspberry Jam
Website: http://camjam.me
Facebook: https://www.facebook.com/cambridgeraspberryjam
Follow the Cambridge Raspberry Jam on Twitter - @cambridgejam
R61zt
Sun Jun 12, 2016 8:22 pm
I'd recommend python for what you are doing.
ben_nuttall
Mon Jun 13, 2016 10:49 am
recantha2 wrote:Python, using the GPIO Zero library would seem to be appropriate.
red = LED(4)
red.on()
GPIO Zero was designed to be the easiest way of programming GPIO devices. It's pre-installed with Raspbian and easy to get started. Just open IDLE (preferably Python 3) and type commands like the above!
See the GPIO Zero documentation for more information, particularly the recipes page for lots of examples of everyday project starter code.
Also see the Foundation's Physical computing with Python resource
Former RPF staff. Author of gpiozero and creator of piwheels.
fan
Mon Jun 13, 2016 4:48 pm
Thanks guys for your help , without you I wouldn't know what to do. I will try gpio zero and then move to pyton or some c solution. Thanks
