Rpi don't install
Posted: Sun Jun 12, 2016 11:19 am
by Ivan219
Hello, i use python 3.4 and have error: I installed rpi:
sudo pip3 install RPi.GPIO
, but when i start: sudo led.py
I have error:
import RPi.GPIO as GPIO
ImportError: No module named 'RPi'
How resolve it?
Re: Rpi don't install
Posted: Sun Jun 12, 2016 11:37 am
by B.Goode
What is the first [ #! ] line of led.py?
And are you using a very old release of the Operating System for your RPi? Because RPi.GPIO has been part of the standard tools included with the OS for ages, you shouldn't need to install it yourself.
Posted: Sun Jun 12, 2016 11:44 am
by Ivan219
The first lines:
import time
GPIO.setmode(GPIO.BCM)
I use Raspabian Jessie
Posted: Sun Jun 12, 2016 12:39 pm
by dgordon42
To install RPi.GPIO for Python3 try:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install python3-rpi.gpio
and follow the prompts.
These commands will update your Pi to the latest version of Raspbian, and install RPi.GPIO for Python 3.
Hope this helps,
Dave.
Posted: Sun Jun 12, 2016 12:43 pm
by B.Goode
I don't think we've got the full story here.
If I try to use RPi.GPIO directly from the Python interpreter REPL I see:
pi@rpi2b ~/ivan $ python3
Python 3.4.2 (default, Oct 19 2014, 13:31:11)
[GCC 4.9.1] on linux
Type "help", "copyright", "credits" or "license" for more information.
Here is my version of your code:
pi@rpi2b ~/ivan $ cat led.py
import time
print("Import test completed OK.")
It runs correctly if the python3 interpreter is invoked directly:
pi@rpi2b ~/ivan $ python3 led.py
If I try to invoke it directly with sudo - which is in any case superfluous - I get a different error:
pi@rpi2b ~/ivan $ sudo led.py
sudo: led.py: command not found
Trying to specify the file in my working directory fails too:
pi@rpi2b ~/ivan $ sudo ./led.py
./led.py: 1: ./led.py: import: not found
./led.py: 2: ./led.py: import: not found
./led.py: 4: ./led.py: Syntax error: word unexpected (expecting ")")
If I put a #! line at the top of the script it works correctly:
pi@rpi2b ~/ivan $ cat led2.py
#!/usr/bin/python3
import time
pi@rpi2b ~/ivan $ sudo ./led2.py
I can't recreate your failure mode: what are you doing differently?
Posted: Sun Jun 12, 2016 1:36 pm
by DougieLawson
You're missing a shebang line.
Add
#!/usr/bin/env python
Then run with sudo ./led.py
Or run with sudo python ./led.py
Posted: Sun Jun 12, 2016 2:14 pm
by Ivan219
Where I must add this line?
DougieLawson wrote:You're missing a shebang line.
Add
Posted: Sun Jun 12, 2016 2:15 pm
by kusti8
Ivan219 wrote:Where I must add this line?
Add
To the top on a new line.
Posted: Sun Jun 12, 2016 2:18 pm
by B.Goode
You could read my reply, where I give an example of using this.
Posted: Sun Jun 12, 2016 3:59 pm
by Ivan219
I tried:
sudo apt-get update
And i got:
The following packages have unmet dependencies:
python3-rpi.gpio : Depends: python3 (< 3.3) but 3.4.2-2 is to be installed
E: Unable to correct problems, you have held broken packages.
Also i tried install via pip3 and it was successful, but if i even do:
pi@raspberrypi ~ $ sudo python3
Python 3.4.2 (default, Jun 7 2016, 13:30:50)
[GCC 4.9.2] on linux
File "<stdin>", line 1, in <module>
After uninstall via pip3 and install again, i got this again
Posted: Sun Jun 12, 2016 4:07 pm
by Ivan219
And with:
#!/usr/bin/python3
or
i have the same error
Posted: Sun Jun 12, 2016 4:53 pm
by Ivan219
I think, that problem in python 3.4... Can i delete him and install it again?
Posted: Sun Jun 12, 2016 5:53 pm
by Ivan219
I haven't any modules on python3.4, but they in dist-packages
Posted: Sun Jun 12, 2016 5:58 pm
by Ivan219
Yes, if I start program from root-user and in idle - all is working. But in console - errors, and in pi-user in idle i have permission (i know that this in normal). How I can resolve, that my programm is working in console?
Sometime ago I made this:
rm /usr/bin/python3
ln -s /usr/local/bin/python3 /usr/bin/
ln -s /usr/local/bin/pip3 /usr/bin/
May be error in this? How delete it?
Posted: Sun Jun 12, 2016 6:08 pm
by Ivan219
I had two python3.4 I delete some files from python3.4 (downloaded), and in console I am getting errors, that i haven't some files.. I want to delete python3.4 (downloaded), and save python3.4 (from OS)
Posted: Sun Jun 12, 2016 6:47 pm
by dgordon42
Remember this thread?
I was trying to determine from you how you came to have several versions of Python on your Pi. The commands you used like:
Ivan219 wrote:rm /usr/bin/python3
won't properly remove or delete python, they will however break your Python installation making it difficult to add, remove, or get anything to work.
Try the following commands to completely remove all versions of Python3, RPi.GPIO and pip3 from your Pi.
sudo apt-get purge python3-pip
sudo apt-get purge python3-rpi.gpio
sudo apt-get purge python3*
Follow the prompts and report any error messages.
Hopefully, this will get rid your damaged Python3 installation.
Reboot.
Get your Pi up to date with:
sudo apt-get update
sudo apt-get dist-upgrade
Reboot.
Install Python3 with:
Report any messages from apt-get.
Install RPi.GPIO for Python3 with:
Copy and save the following program to your home directory as "testing+RPI+P3.py"
#!/usr/bin/env python3
print(GPIO.VERSION)
Make the file executable with the command:
chmod 744  testing+RPI+P3.py
Run the program from your home directory with:
./testing+RPI+P3.py
Report the output.
If you cannot get this to work, I would advise that you back up any data you have on the SD card, and re install Raspbian.
Hope this helps,
Dave.
Posted: Sun Jun 12, 2016 8:51 pm
by Ivan219
After
deleted GUI, and after reboot too... I made bakcup before this. And I think that I could reinstall raspabian...
