Ivan219
Do not load the OS
Sun Jun 05, 2016 8:52 pm
Hello, I have problem: Raspabian jessie don't load when raspberry starting work, (yesterday all were ok) I can't write anything in console, and graphical interface is also not loaded, when raspberry starting work I see two "faileds" - failed to start load kernel modules and failed to start console system startup logging. How i can resolve it without having to reinstall the system, SD CARD - working good, i can see all files, when i connect it to another computer. Yesterday, i were mading timelapse video, but after 15 frames this failure occurred. Please, help.
DirkS
Re: Do not load the OS
Sun Jun 05, 2016 8:55 pm
Is your card (almost) full?
Ivan219
Sun Jun 05, 2016 9:19 pm
Yesterday, yes, it was for five minutes, because i forgot about memory and photoses were making, but i delete some files and had 4,5 GB Free and after reboot all were working normal.
broe23
Mon Jun 06, 2016 2:33 am
You may want to get a USB case with a SSD to keep files on, instead of risk losing them if the SD Card goes bad.
Even better if you plan on writing code. Setup a 8gb Class 10 SD with just the Boot Loader and SSD with thr OS and files.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good.
Ivan219
Mon Jun 06, 2016 8:47 am
Thank you for your reply. I inderstand, that now I must download image to external media and write smt to cmd. And past data os will not run?
