accuracy in measuring temperature
Posted: Sat May 21, 2016 3:57 pm
by LLYY
I'm searching for a temperature sensor with 0.1C accuracy, the best that I found so far is the DS18B20 model.
Are there other temperature sensors that hiding somewhere?
Thank You!
Re: accuracy in measuring temperature
Posted: Sun May 22, 2016 1:49 am
by masa-aud
reply to LLYY on accuracy in measuring temp
It is important to refer accuracy of mostly used AD converters for RPi or Arduino as at most about 1/4000 that is 12bit type, seems to fit practically to that 0.1 C.
masa
Posted: Sun May 22, 2016 2:36 am
by masa-aud
From connection to GPIO of RPi point of view, recommended type of device is such having digital interface as I2C or SPI, that sensor output already converted with built-in ADC then to digital but not so fine as your referring sample DS18B20 as +- 0.5C.
If you plan a kind of 0.1C then some precision amplifier circuits needed added to sensor and ADC.
I think it's good to try first a DS18B20 then to your next system.
masa
Posted: Sun May 22, 2016 3:11 am
by Gavinmc42
I use i2c sensors, multiple addresses so you can have a string of them.
TMP112, TMP175 - 0.0625C resolution.
TMP112 can be calibrated for even more accuracy.
