fotoartist78
Using Usb port on Pi3 to ouput from Sonicic
Sat May 21, 2016 11:24 am
On the Pi3 can sound be output via a USB port to Usb speakers. Is any software required. ?
masa-aud
Re: Using Usb port on Pi3 to ouput from Sonicic
Sat May 21, 2016 1:01 pm
reply to fotoartist78 on Using Usb port on
You need to know that there are 2 types i.e. a set of speakers works as an USB device which should be identified by OS to receive digital audio signal, and works using headphon jack with built in amplifier receiving analog audio signal from Pi's own output and both will be feeded power from USB. So try firstly configuration for your speaker type.
masa
