milinpatel
using PI zero GPIO pins
Fri May 20, 2016 8:20 pm
hi,
I am using pi zero for my project.So for that I want to program some of the GPIO pins by application programming.
Now,i want to know two things
1)Befor starting to program the GPIO pins i want to know it's default status so ,where i can find the default status of GPIO pins for
"pi Zero" module.
2)How to access or program the GPIO pin by "application programming".
W. H. Heydt
Re: pi zero
Sat May 21, 2016 2:08 am
Use the resources that you would use for the GPIO pins for any other Pi. The only difference is that you have add the physical header pins yourself on a Pi Zero.
B.Goode
Re: pi zero
Sat May 21, 2016 9:53 am
milinpatel wrote: 2)How to access or program the GPIO pin by "application programming".
viewtopic.php?f=91&t=148726
ben_nuttall
Re: using PI zero GPIO pins
Fri May 27, 2016 11:25 am
1. Solder the pins on
2. Refer to http://pinout.xyz
3. Try some simple programs using Python and GPIO Zero (also see this resource)
Former RPF staff. Author of gpiozero and creator of piwheels.
