Arduino + Raspberry Pi connection through 3.3 and relay?
Posted: Wed May 18, 2016 9:37 am
Hi
I asked a while ago on how to connect an arduino and a raspberry pi together, so that a button press on the Arduino would result in a file playback on the RPi.
The answers I got on this matter was that the Uno and the RPi could not directly be connected together because the HIGH signal on a RPi is just 3.3V and the HIGH on the Arduino is 5V.
So that would not work, and I've tried finding voltage levelers in Norway but I could not find any that would suit my purpose, so I am left ordering from China.
Thing is, I really need this to work before I receive this parcel. I tried connecting ARduino to RPi on USB and it worked to some extent, the problem is they are going to be a little farther away so I think wireing would be better.
Now here is my idea:
Could I wire the Uno and the RPi together on 5V supply(connect the Arduino to a regulated 5V supply through the UNO's 5v port. They would then also share ground on this 5V power supply.
THEN, how about I also add a relay which I have lying around (One channel 5V relay for Arduino) to the loop in this manner:
Vcc - To 5V regulated along with Uno and RPi
Gnd - Obviously to GND
Signal - to random Arduino digital pin.
And,
C(common) to Arduino 3.3V port
NO to RPi GPIO pin?
Would this then work the way I want it to?
If I code the RPi something like this?
The reason I can't just use the RPi as my main console is that there are numerous other things connected to the Arduino, like a LCD display etc. etc. etc.
What do you think? Is it possible?
And,
NO to RPi GPIO pin?
import pygame.mixer
from time import sleep
import RPi.GPIO as GPIO
from sys import exit
GPIO.setmode(GPIO.BCM)
GPIO.setup(4, GPIO.IN)
pygame.mixer.init(48000, -16, 1, 1024)
snd = pygame.mixer.Sound("game.wav")
soundChannelA = pygame.mixer.Channel(1)
while True:
try:
if (GPIO.input(4) == True):
soundChannelA.play(sndA)
