mattanl
EU Power supply
Fri Aug 17, 2012 2:52 pm
Which power supply should I buy?
How many mA will be the best for the raspi?
Is this model will be good enough?
http://www.dealextreme.com/p/usb-power- ... plug-48615
Can someone explain about the required mA? the greater the better? are there limits?
Thank.
RaTTuS
Contact: Twitter YouTube
Re: EU Power supply
Fri Aug 17, 2012 3:00 pm
http://elinux.org/RPi_Hardware#Power
that one should be good enough as long as your USB -> micro USB cable is not made of wet sting.
Covfefe
redhawk
Re: EU Power supply
Fri Aug 17, 2012 4:30 pm
The PI's polyfuse (F3) will limit it's ability to use anything more than 750ma so even if you use a power supply rated at 5v@2A or 5v@750ma the extra current won't make a difference.
What does matter is the effectiveness of a power supply to keep a steady voltage with respect to current most loaded power supplies will drastically drop their voltage output.
The only way to test this on the PI is to load the board with USB device and then measure the voltage at TP1 / TP2 the PI really needs 4.75v or higher to function correctly.
Richard S.
mattanl
Re: EU Power supply
Fri Aug 17, 2012 7:46 pm
Thanks!
Seems like the model I wrote will be good enough (5V, 1A).
Am I right?
hibol
Re: EU Power supply
Fri Aug 17, 2012 7:52 pm
It should be ok, but beware of no name and cheap devices.
For this price, I wonder what quality this power supply is.
Return to “Beginners”
