coskukoz
If Status Change Print
Fri May 13, 2016 5:36 am
Hello guys,
It's easy but I didn't find a code exactly what I want. That's why I post a topic. I'm trying to write a code like: if status change print as you can see on the topic.
For example;
If status ON: print ON to the screen once,
If status change with OFF: print OFF to the screen once.
My code prints ON in the per second so I see so many ON on the screen. Hope I explain well.
Now my code is:
import spidev
import time
import os
import urllib
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
spi=spidev.SpiDev()
spi.open(0,0)
def ReadChannel (channel):
 adc = spi.xfer2([1,(8+channel)<<4,0])
 data = ((adc[1]&3)<<8) + adc[2]
 return data
def ConvertVolts(data,places):
 volts = (data*3.1815)/float(1023)
 volts = round(volts,places)
 return volts
sensor1_channel = 1
while True:
 foldtime = time.time()
 fnewtime = time.time()
 fstore = 0.1
 while True:
  fdtime = fnewtime-foldtime
  sensor1_level = ReadChannel(sensor1_channel)
  sensor1_volts = ConvertVolts(sensor1_level,9)
  if sensor1_volts > 1.60:
   Durum = 'ON'
  else:
   Durum = 'OFF'
  if fdtime >= fstore:
   foldtime=fnewtime
   print('------------------------')
   print("Sensor1 : {} V,     {}".format(sensor1_volts,sensor1_level))
   print("Durum : {}".format;(Durum))
time.sleep(delay)
Thanks for helps!
Coskun.
EDIT:
I solved the issue with the code below:
import spidev
import time
import os
import urllib
spi=spidev.SpiDev()
spi.open(0,0)
 return data
 return volts
sensor1_channel = 1
previous_Status = None
fstore = 3.0
while True:
  foldtime = fnewtime
   Status = 'ON'
  elif sensor1_volts <= 1.60:
   Status = 'OFF'
  if Status != previous_Status:
   print("Status : {}".format;(Status))
   previous_Status = Status
time.sleep(delay)
cactiapps.blogspot.com
