davenull
change HDMI screen resolution manually during runtime?
Wed May 11, 2016 8:20 am
hi,
is it possible to change HDMI screen resolution manually during runtime?
Temporarily I am using a 1920x1080 HDMI TV screen for desktop programming, but than I have to switch to a 800x480 TFT for the mobile robot application to run,
so I want to unplug the full HD TV screen and change to the small TFT, and then vice versa, without intermediate rebooting.
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
Re: change HDMI screen resolution manually during runtime?
Wed May 11, 2016 7:36 pm
Have a look at the tvservice command. The source is available at https://github.com/raspberrypi/userland
davenull
Wed May 11, 2016 10:02 pm
tvservice? is that a subfolder or a program in a subfolder?
DirkS
Thu May 12, 2016 8:20 pm
davenull wrote:tvservice? is that a subfolder or a program in a subfolder?
A program (already installed on RPF Raspbian images). Source is in the userland repo Dougie linked to (https://github.com/raspberrypi/userland ... /tvservice)
davenull
Fri May 13, 2016 8:33 am
I see, tvservice is already installed -
how do I have to use that? Is there a description available?
davenull
Fri May 13, 2016 1:32 pm
no idea which parameters I have to use for the pixel resolution settings to switch between
1920x1080 and 800x480 (both 16:9)
procount
Fri May 13, 2016 1:40 pm
`tvservice` on its own will give you a list of parameters.
Use
`tvservice -s` to show your current status
`tvservice -m DMT` to show available modes (mostly for digital monitors?)
`tvservice -m CEA` to show available modes (mostly for TVs?)
`tvservice -e ......` to set your required mode
davenull
Fri May 13, 2016 1:56 pm
yes, thank you, I saw that already entering tvservice in a terminal -
but I still don't see which parameters I have to use for the pixel resolution settings to switch between
required DMT modes might be 9 or 87 and 82.
but, e.g.:
tvservice -e mode 82
does not work
so what is correct?
DirkS
Fri May 13, 2016 3:02 pm
davenull wrote:does not work
so what is correct?
Do you actually read what you see on screen?
-e, --explicit="GROUP MODE DRIVE" Power on HDMI with explicit GROUP (CEA, DMT, CEA_3D_SBS, CEA_3D_TB, CEA_3D_FP, CEA_3D_FS)
So you write group, mode and drive in quotes with the -e option.
Example:
tvservice --explicit="CEA 16 HDMI"
See e.g. https://www.raspberrypi.org/documentati ... fig-txt.md for description of groups, modes and drive.
davenull
Fri May 13, 2016 3:04 pm
I honestly don't understand a single word.
What is group? what is drive? I only need the resolution!
couldn't you provide the complete commands, please?
no -e parameter?
hell, that's awfully weird that stuff to me! :evil:
DirkS
Fri May 13, 2016 3:06 pm
davenull wrote:I honestly don't understand a single word.
no -e parameter?
that's awfull weird that stuff to me! :evil:
Dif you follow the link I gave you?
davenull
Fri May 13, 2016 3:07 pm
don't understand what they are writing - too many words, too many ambigouos and weird explanations - I don't get it.
procount
Fri May 13, 2016 3:18 pm
You have to be more precise in what parameters you type for tvservice,
There are 2 groups: CEA and DMT
You have to get the list of available modes for each group, so to get a list of CEA modes, type:
tvservice -m CEA
and to get a list of DMT modes that your monitor supports, type:
tvsservice -m DMT
Then choose the mode you want (e.g. 82) from the group you want (e.g. DMT) and whether you want HDMI or DVI output (e..g. HDMI), and type, (for example):
tvservice -e "DMT 82 HDMI"
The last parameter (HDMI) is optional. You must include the quotes.
davenull
Fri May 13, 2016 3:20 pm
my old setting was 800x480 for my small TFT.
for it I had to add to /boot/config.txt
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 800 480 60 6 0 0 0
start_file=start_x.elf
fixup_file=fixup_x.elf
#gpu_mem=128
Then I plugged a full HD screen instead.
It still showed the small resolution at start up (800x480).
I now tried
tvservice --explicit="DMT 82 HDMI"
but then the screen was black, nothing visible any more
(I had plugged a full HD screen, HDMI-to-DVI adapter in between).
Had to hot-unplug the Pi.
So what's the correct command?
procount
Fri May 13, 2016 3:26 pm
It depends on what your monitor supports.
Make sure the mode number you use is appropriate for the CEA or DMT mode that your monitor said it supports.
Sometimes it goes blank because you need to set the framebuffer to match the new resolution.
When it goes black type:
fbset -depth 8
fbset -depth 16
davenull
Fri May 13, 2016 3:28 pm
ok - thanks - but now it's getting far too weird to me.
I have no idea about all those low level hardware stuff.
and how should I type anything if I don't see what I type?
IMO Linux should show the available screen resolutions just like Windows does, to choose by a menu
Is there no other way to adjust the resolution?
If not, then I have to abandon that stuff
:evil:
davenull
Fri May 13, 2016 3:37 pm
writing all that into a bash script, it didn't change anything then nevertheless - all stayed as it was before at 800x480:
fbset -depth 8
fbset -depth 16
procount
Fri May 13, 2016 3:46 pm
A bash script is a good idea.
Try some other mode numbers. or try CEA and appropriate numbers for that group as well.
davenull
Fri May 13, 2016 3:48 pm
82 is the only 1920X1080 mode, and it worked automatically for that resolution before I had to force the config.txt changes for the small TFT
davenull
Fri May 13, 2016 3:52 pm
tvservice -m CEA
has 0 modes
procount
Fri May 13, 2016 3:55 pm
Why don''t you just remove the config.txt changes for the TFT then and reboot?
Maybe keep 2 config.txt files, one for each screen that you attach and copy the one you want.
procount
Fri May 13, 2016 3:56 pm
Also try
tvservice -p
which will set the monitor to its preferred mode, which is normally the best one.
davenull
Fri May 13, 2016 4:03 pm
preferred is currently mode 87for the small 800x480 TFT which I already forced to by
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
#gpu_mem=128
