davenull
Re: SD backup on the Pi during runtime: rpi-clone? alternati
Fri May 13, 2016 11:39 am
what?
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
B.Goode
Read the final paragraph "How do I get it?" at the end of the blog post.
davenull
Fri May 13, 2016 11:41 am
ah, ok, thank you, I only had read the part about the SD copy tool.
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install piclone geany usb-modeswitch
wilco!
Fri May 13, 2016 11:42 am
davenull wrote:ah, ok, thank you, I only had read the part about the SD copy tool.
sudo apt-get update
wilco!
:roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
RPi 4B 4GB (SSD Boot)..
davenull
Fri May 13, 2016 11:52 am
what?
or are you just trolling?
Fri May 13, 2016 11:58 am
davenull wrote:what?
Not at all, just rolling eyes at your responses to my post regards you not reading the WHOLE BLOG :D
davenull
Fri May 13, 2016 12:04 pm
no I actually never read whole blogs (and also not entire encyclopedias) if I need just single informations :roll:
davenull
Fri May 13, 2016 2:34 pm
that tool looks really awesome!
I just have started a SD copy and then will check it.
BTW, is there something like a disk compare tool to verify the SD copy when finished ?
Return to “Beginners”
