200yrs
TightVNC to install on Raspberry PI without internet.
Fri May 06, 2016 8:25 am
Hello Mates...really need help...tried my best to research and study but can't get it to work. I want to install tightvnc into my raspberry pi without using internet...please help to the right direction. Downloaded tightvncserver_1.3.9-6.4_armhf.deb but can't install using command --> sudo dpkg -i tightvncserver_1.3.9-6.4_armhf.deb.
Looking for libc6...so i downloaded libc6_2.13-38+deb7u10_armhf.deb and install but got error as below.
[email protected]:~/DebTightVNC $ sudo dpkg -i libc6_2.13-38+deb7u10_armhf.deb
(Reading database ... 126574 files and directories currently installed.)
Preparing to unpack libc6_2.13-38+deb7u10_armhf.deb ...
Unpacking libc6:armhf (2.13-38+deb7u10) over (2.19-18+deb8u3) ...
dpkg: warning: subprocess old post-removal script was killed by signal (Segmentation fault)
dpkg: trying script from the new package instead ...
dpkg: error processing archive libc6_2.13-38+deb7u10_armhf.deb (--install):
subprocess new post-removal script was killed by signal (Segmentation fault)
dpkg: error while cleaning up:
subprocess installed pre-installation script was killed by signal (Segmentation fault)
Really need help...thanks in advance.
200yrs
Re: TightVNC to install on Raspberry PI without internet.
Sat May 07, 2016 2:28 am
Raspberry Pi experts...a little help here please....thanks a lot.
MarkHaysHarris777
Sat May 07, 2016 2:48 am
200yrs wrote:Hello ... want to install tightvnc into my raspberry pi without using internet...please help to the right direction.
Why?
... get an Internet connection and install it from the repositories. Why make this hard on yourself?
Well, and the main point is that there is not much point to VNC in the first place without a network connection. (there are uses, but)
marcus
:ugeek:
200yrs
Sat May 07, 2016 2:59 am
We have network (connected by lan) but I am working in the place that our IT block the internet to all Rasberry PI for some reason. Have no issue using Putty and WinSCP....The reason I want tightvnc to be installed because from time to time i am updating the presentation into our Pi display...It is very time consuming to use pendrive to transfer and run the presentation, i want to access the Pi display using my windows PC and run the presentation...hope i made mymessage clear....help please...thanks.
MarkHaysHarris777
Sat May 07, 2016 3:44 am
200yrs wrote: ... network [is] (connected by lan) but I am working in the place [where] our IT blocks the internet to all Rasberry PIs for some reason.
Uffdah!
IAN connections are the best most secure connections... I wonder why the PIs are blocked?
Where are you located, working?
marcus
:ugeek:
200yrs
Sat May 07, 2016 4:31 am
Located in Malaysia...so please let me know if it is possible or not...I really like to try...thanks
klricks
Sat May 07, 2016 4:49 am
Do yourself a huge favor and either talk to your IT people to get access or take the RPi somewhere that has Internet access.
Note if you want to access and control the local session on the RPi then use x11vnc instead of tightvnc.
200yrs
Sat May 07, 2016 8:12 am
Please share procedure to install "x11vnc". I am very reluctant to ask help with IT, they move very slow :-(
I want to resolve faster....thanks.
Sat May 07, 2016 8:24 am
Get a second RPi with internet access, build everything you need on it's SDCard, clone that to another SDCard and use that on the disconnected machine.
200yrs
Sun May 08, 2016 12:37 pm
Look guys....if internet is not an issue, I would not spend time here asking this question....But thanks to those who tried responding.
I can see that there's no way can install vnc without internet.. :cry:
Candyjet
Sun May 08, 2016 1:27 pm
What is the advantage of x11vnc over tightvnc?
procount
Sun May 08, 2016 2:53 pm
Maybe have a look at PiKitchen recipe 008 VNC which installs vnc without internet.
https://pihw.wordpress.com/guides/pi-kitchen
klricks
Sun May 08, 2016 3:13 pm
Candyjet wrote:What is the advantage of x11vnc over tightvnc?
When using tightvnc, XRDP, SSH, they all open new and independent session(s). Several users could log into the same RPi and each would not know about the other.
x11vnc allows the user to see and use the local desktop session. The screen where the actual keyboard/mouse/monitor is attached will be mirrored to the remote connection.
There may be ways to get the others to work like that but x11vnc just works.
Google how to install.
klricks
Sun May 08, 2016 3:24 pm
200yrs wrote:Look guys....if internet is not an issue, I would not spend time here asking this question....But thanks to those who tried responding.
You have to have access to the Internet anyway to get the packages.
It may be possible but you could spend days trying to get all the dependencies sorted and downloaded.
You could DL the whole repository and create a local repository inside your LAN. I'm not sure how feasible that is but others in your situation have done it.
200yrs
Mon May 09, 2016 12:59 am
It's fine how long I can finish installation...all am asking is a guide...a step by step guide...thanks mates.
MarkHaysHarris777
Mon May 09, 2016 2:10 am
200yrs wrote:It's fine how long I can finish installation...all am asking is a guide...a step by step guide...thanks mates.
Sorry, mate.
marcus
:ugeek:
stderr
Mon May 09, 2016 2:37 am
200yrs wrote: I want to install tightvnc into my raspberry pi without using internet...please help to the right direction. Downloaded tightvncserver_1.3.9-6.4_armhf.deb but can't install using command --> sudo dpkg -i tightvncserver_1.3.9-6.4_armhf.deb.
If you want to install things from deb files, you are going to have to do all the dependency management yourself. This can be very difficult no matter what the kind folks over at slackware claim, witness trying to compile omxplayer on tiny core linux.....
Sometimes, you can get a deb file where the author has included or otherwise explained what to do to get it to install. But often these deb files come from the archive used by apt-get et al. and you are being expected to use apt-get et al. and not directly install with dpkg -i .
So I'd say to look into using apt-get for this. You can get it to print out the urls for the needed downloads like this:
sudo apt-get install --print-uris whateverPackageName
stderr
Mon May 09, 2016 2:39 am
There are various programs that attempt to do what you want including, I haven't tried this one, apt-offline and others. It surprises me that no one else around here has this issue since all it takes is a pi stuck up in a tree doing datalogging and you come by every once in a while and wifi into it to download the data and presumably upload updates but there's no internet available.
procount
Tue May 17, 2016 12:43 pm
@200yrs.
Not sure why you are having so much trouble.
I just installed the latest Raspbian from 2016-05-10.
I copied tightvncserver_1.3.9-6.4_armhf.deb and xfonts-base_1.0.3_all.deb to my pi in ~/deb
then did:
[email protected]:~/deb $ sudo dpkg -i tightvncserver_1.3.9-6.4_armhf.deb
Selecting previously unselected package tightvncserver.
(Reading database ... 117963 files and directories currently installed.)
Preparing to unpack tightvncserver_1.3.9-6.4_armhf.deb ...
Unpacking tightvncserver (1.3.9-6.4) ...
Setting up tightvncserver (1.3.9-6.4) ...
update-alternatives: using /usr/bin/tightvncserver to provide /usr/bin/vncserver (vncserver) in auto mode
update-alternatives: using /usr/bin/Xtightvnc to provide /usr/bin/Xvnc (Xvnc) in auto mode
update-alternatives: using /usr/bin/tightvncpasswd to provide /usr/bin/vncpasswd (vncpasswd) in auto mode
Processing triggers for man-db (2.7.0.2-5) ...
[email protected]:~/deb $ sudo dpkg -i xfonts-base_1.0.3_all.deb
Selecting previously unselected package xfonts-base.
(Reading database ... 117983 files and directories currently installed.)
Preparing to unpack xfonts-base_1.0.3_all.deb ...
Unpacking xfonts-base (1:1.0.3) ...
Setting up xfonts-base (1:1.0.3) ...
Processing triggers for fontconfig (2.11.0-6.3) ...
[email protected]:~/deb $ vncserver --help
TightVNC Server version 1.3.9
Usage: vncserver [<OPTIONS>] [:<DISPLAY#>]
       vncserver -kill :<DISPLAY#>
<OPTIONS> are Xtightvnc options, or:
        -name <DESKTOP-NAME>
        -depth <DEPTH>
        -geometry <WIDTH>x<HEIGHT>
        -httpport number
        -basehttpport number
        -alwaysshared
        -nevershared
        -pixelformat rgb<NNN>
        -pixelformat bgr<NNN>
See vncserver and Xtightvnc manual pages for more information.
[email protected]:~/deb $ vncserver :1
You will require a password to access your desktops.
Password:
Warning: password truncated to the length of 8.
Verify:
Would you like to enter a view-only password (y/n)? n
New 'X' desktop is raspberrypi:1
Creating default startup script /home/pi/.vnc/xstartup
Starting applications specified in /home/pi/.vnc/xstartup
Log file is /home/pi/.vnc/raspberrypi:1.log
Maybe you just have an underlying problem with your original SD card installation....*shrug*
