windy54
Raspberrypi.org/ push button animation - problem with omxpla
Sun May 01, 2016 4:52 pm
I have just tried the push-button-animation from raspberrypi.org / make worksheet with my grandson and the created mp4 file does not play with omxplayer.
So, we started with a clean installation of Jessie and followed the instructions to install the software and create the python script.
We had a set of jpg files in a folder called animation as per the instructions.
Had to change
avconv -r 10 -qscale 2 -i animation/frame%03d.jpg animation.mp4
to
avconv -r 10 -i animation/frame%03d.jpg -qscale 2  animation.mp4
in order to create the mp4 file, the qscale option has to be after the input files, otherwise an error is generated by avconv.
The mp4 file is created but when we run omxplayer as
omxplayer animation.mp4
we get
Video codec omx-h264 width 1920 height 1080 profile 100 fps 10.000000
Subtitle count: 0, state: off, index: 1, delay: 0
and no video
i have searched the internet but have not found a solution that works
we have tried
omxplayer -o hdmi animation.mp4
has anyone got any suggestions
cheers
Steve
windy54
Re: Raspberrypi.org/ push button animation - problem with om
Sun May 01, 2016 7:17 pm
Just sorted it, not enough frames!
created an animation with 20 frames and it worked.
I found a post on the internet where some one said they had problems because omxplayer was too quick, their mp4 file was too short.
with 20 frames it worked a treat.
