himani18
how to increase video duration of on going recording
Fri Apr 29, 2016 2:45 pm
hey..
i am using the below code...
problem with this is that I can record video only upto 3 seconds...
so can anyone tell me how to increase the duration of on going recording...
suppose i want to set predefined 20sec of continous recording...
import RPi.GPIO as GPIO
import time
import picamera
import datetime
def file_name():
        return datetime.datetime.now().strftime("/home/pi/programs/test/video/%Y-%m-%d_%H.%M.%S.h264")
 sensor=7
GPIO.setmode(GPIO.BOARD)
GPIO.setup(sensor, GPIO.IN, GPIO.PUD_DOWN)
previous_state=False
current_state=False
cam=picamera.PiCamera()
frame=5
while True:
    time.sleep(0.000001)
    previous_state=current_state
    current_state=GPIO.input(sensor)
    if current_state!=previous_state:
        new_state="HIGH" if current_state else "LOW"
        print("GPIO pin %s is %s"%(sensor,new_state))
        if current_state:
                fileName=file_name()
                cam.start_preview()
                cam.start_recording(fileName)
                time.sleep(2)
                cam.stop_preview()
                cam.stop_recording()
GPIO.cleanup()
beta-tester
Re: how to increase video duration of on going recording
Fri Apr 29, 2016 7:21 pm
i never used the python module, but the raspivid will expect a parameter if you want to record a video longer than 5 sec.
possibly in python you have to provide a similar parameter/attribute as well.
EDIT: forget what i saied.
why do you stop recording after 2 seconds...when you intend to record 20 seconds... ?
time.sleep(2)
{ I only give negative feedback }
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
shuckle
Fri Apr 29, 2016 7:26 pm
Change time.sleep(2) to be time.sleep(20)
himani18
Sat Apr 30, 2016 4:37 pm
And is there any way that my motion should not be identified...
Or like if my motion gets detected it should nt record video
B.Goode
Sat Apr 30, 2016 4:43 pm
himani18 wrote: if my motion gets detected it should nt record video
Just invert the logic of the test at if current_state:
himani18
Sun May 01, 2016 12:32 pm
only my motion shouldn't be detected...
it should detect motion of rest of the ppl...
Return to “Beginners”
