vbman213
Wi-Fi performance varies between two identical raspi3?
Sun Apr 24, 2016 5:10 pm
Two new Raspberry Pi 3s (left and right):
http://i.imgur.com/6gJJ0dC.jpg
Both running identical software.
iPerf3 test (left):
iPerf3 test (right):
What could be causing such a sharp difference in performance? Both Pi3s are associated with the same access point, in the same physical location.
mikronauts
Re: Wi-Fi performance varies between two identical raspi3?
Sun Apr 24, 2016 7:24 pm
Disable power management for the Pi3 on the right - I've seen this issue discussed in the forum.
vbman213
Sun Apr 24, 2016 8:02 pm
As have I, but what differences between these two identical Pi's (same hardware and same software) would cause such a sharp contrast in performance?
FTrevorGowen
Sun Apr 24, 2016 8:36 pm
vbman213 wrote:As have I, but what differences between these two identical Pi's (same hardware and same software) would cause such a sharp contrast in performance?
Just to confirm the situation - are you literally using the same (external) hardware and software ie. uSDHC card, power supply, cables etc. and just swapping the Pis? (Power supply and/or uUSB power cable differences could contribute)
Trev.
drgeoff
Sun Apr 24, 2016 9:32 pm
If the photo is of the actual setup giving the different measurements, the first thing I would do is to move that huge paperclip away. Its size is comparable with half a wavelength of 2.4GHz and could be affecting field strengths differently depending on the direction to the Access Point.
Dis93
Sun Apr 24, 2016 9:48 pm
meta
vbman213
Sun Apr 24, 2016 9:55 pm
Trev.
Yes. Same PSU, power cable, HDMI->DVI, and monitor. The only thing that is different is the Pi3 board itself.
I will move the paperclip...
