Deleting a media source
Posted: Fri Apr 22, 2016 1:46 am
by AlexanderBB
Under Videos-Files (with KODI UI) how can I remove redundant folders (as they no longer exist)?
I've tried selecting them in "Add Video" then Remove but can't quite make it work,
Thanks for any help.
Re: Deleting a media source
Posted: Fri Apr 22, 2016 10:06 am
by DirkS
Maybe with 'Clean Library'?
I see this in Settings / Video / Library, but it depends on which skin you use...
Posted: Fri Apr 22, 2016 10:14 am
by Goraxium
Depending on your setup, a long press may bring up a menu with the 'remove source' option. If that doesn't work, there is an option *somewhere* (I only found it once) that will enable the long press option. Alternatively, a right click on a mouse will bring the menu up too.
Posted: Sat Apr 23, 2016 2:19 am
by AlexanderBB
Thanks very much for the info. Under Settings / Video / Library I couldn't see a Clean option but attaching a mouse worked. :D
