jphh
NEW SD CARD
Wed Apr 20, 2016 3:17 pm
I got a Pi 3. Followed the instructions with sd card 32gb formatted fat32. Downloaded NOOBS (cannot remember if it was 1.8 or 1.9) and started without problems.
I now have a 64gb sd card also formatted in fat32. Followed the same procedure with NOOBS 1.9. Pi 3 does not boot as if it was not seeing the sd card.
Help please.
JP
drgeoff
Re: NEW SD CARD
Wed Apr 20, 2016 3:58 pm
1. Are you sure the 64Gbyte card is FAT32? They invariably come as exFAT and most formatters will also return them to exFAT.
2. Could the 64 Gbyte card be a fake?
anand1
Contact: Website Yahoo Messenger
Re: NEW SD CARD
Wed Apr 20, 2016 4:02 pm
I recommend to use SDFomatter v4.0. And check if FAT 32 option is selected....
DirkS
Re: NEW SD CARD
Wed Apr 20, 2016 4:42 pm
anand1 wrote:I recommend to use SDFomatter v4.0. And check if FAT 32 option is selected....
There is no option in SDformatter to change the format.
jphh
Re: NEW SD CARD
Wed Apr 20, 2016 8:48 pm
drgeoff wrote:1. Are you sure the 64Gbyte card is FAT32? They invariably come as exFAT and most formatters will also return them to exFAT.
The card is a San Disk Ultra class 10 bought on Amazon .
It was formatted on my MacBook Pro as a Fat32 and the files can be seen on "finder"
jahboater
Re: NEW SD CARD
Thu Apr 21, 2016 7:10 am
Or try installing the Raspbian OS image directly - there is no need to format the disk first, and Raspbian itself can deal with any sized disk.
https://www.raspberrypi.org/downloads/raspbian/
Pi4 8GB running PIOS64
jphh
Re: NEW SD CARD
Thu Apr 21, 2016 5:11 pm
jahboater wrote:Or try installing the Raspbian OS image directly - there is no need to format the disk first, and Raspbian itself can deal with any sized disk.
I have now successfully downloaded and installed Raspbian image directly and Pi 3 does boot.
However "df -h" now returns a filesystem size of 3.6G for my SD card of 64gb compared with 28G when I was using a 32gb sd card.
Help please
JP
DirkS
Re: NEW SD CARD
Thu Apr 21, 2016 5:51 pm
Expand the filesystem.
Use
sudo raspi-config
on the command line or start the GUI configuration utility (IIRC that's in Menu / preferences)
Should be the first option in both.
jphh
Re: NEW SD CARD
Thu Apr 21, 2016 9:59 pm
DirkS wrote:Expand the filesystem.
Use
sudo raspi-config
Problem solved. Thanks to all.
