hasanoa
problem, because of multiple running of python codes
Wed Apr 20, 2016 7:04 am
Hi everyone,
I added followed lines to end of /etc/profile file. (adding .bashrc causes the same result)
sudo python /home/pi/shutdown.py &
sudo python /home/pi/output.py &
After start up, I found 6 process for shutdown.py and 6 process for output.py as attached img.
Is it possible to solve this problem?
Thank you
DirkS
Re: problem, because of multiple running of python codes
Wed Apr 20, 2016 9:29 am
/etc/profile is used for every login, so if multiple users log in it will be started multiple times.
You could add it to /etc/rc.local or use a system service to start the scripts.
For Jessie see e.g. http://www.raspberrypi-spy.co.uk/2015/1 ... g-systemd/
hasanoa
Wed Apr 20, 2016 10:18 am
Hi DirkS,
- "rc.local" option did not solve my problem. It did start nothing.
- "system service" option fixed the problem.
Thank you for your help
DirkS
Wed Apr 20, 2016 10:30 am
Good. I think using a system service is the better solution of the two.
hasanoa wrote:- "rc.local" option did not solve my problem. It did start nothing.
Should have worked. I forgot to mention that you need to put your commands before the line 'exit 0'
hasanoa
Wed Apr 20, 2016 11:12 am
It's ok, system services are working very well. I configured 2 different service for 2 different python...
Thank you again...
