Lxw2015
jessie user/password
Sun Apr 17, 2016 10:27 pm
Hi, I have OS Jessie on my raspberry pi. when boots up, it won't ask me for user and PW. after I did "sudo get-apt update" then reboot. it ask me user & PW. I tried user: pi, PW: raspberry. it tell me incorrect.
I wonder why after update then ask user/PW, and what are they?
thanks
Xianwu
DirkS
Re: jessie user/password
Sun Apr 17, 2016 10:38 pm
Did you install Raspbian using Noobs or did you use the image file?
If you used an image then you could be running out of disk space.
Did you expand the filesystem after installation?
Rive
Sun Apr 17, 2016 10:40 pm
If it was set for auto login prior to update, then required user login after update, and you did not uncheck the box in raspi-config, then something is wrong.
You may need to restore.
DNPNWO
Lxw2015
Sun Apr 17, 2016 10:59 pm
by DirkS » Sun Apr 17, 2016 10:38 pm
A: I download Jessie from raspberrypi.org and burn it on Mini SD card using Win32DiskImager.
A: I check the Mini SD, used ~20MB, and 40MB free
A: how to ? I don't think I did. min SD contains overlays folder and some .dtb and other files in root folder.
Report this postReply with quotePermalink
by Rive » Sun Apr 17, 2016 10:40 pm
then what is Jessie's user/pw?
thanks for reply.
LuoXW
klricks
Sun Apr 17, 2016 11:06 pm
When you install the standalone image (not NOOBS) then as soon as possible (preferably first boot), you must expand the filesystem and reboot BEFORE doing ANYTHING else. Do not do any updates or installations until after this is done.
Use the first option in the config tool [Menu] --> [Preferences] --> [Raspberry pi configuration]
-OR- from LXTerminal command prompt:
sudo raspi-config
option 1.
You will need to write the image again with Win32diskimager then do the above.
Lxw2015
Sun Apr 17, 2016 11:15 pm
I download Jessie, unzip it. then write to SD. and it worked fine. I did not expand file system. the problem happened after I did update. what do you mean I have to expand file system ?
thanks
Rive
Sun Apr 17, 2016 11:28 pm
thanks for reply.
IF you uncheck the box for AUTO LOGIN "login as User Pi" in Raspberry Pi Config, and have NOT changed the default password, it will then prompt you for the username (pi) and password (raspberry) at startup.
If you did not stop autlogin, and you did not change the default password, and you are being prompted for them at startup greet screen, and the defaults do not work, then something may be corrupted.
There is no other password for user 'pi' to try.
DNPNWO
klricks
Sun Apr 17, 2016 11:32 pm
Lxw2015 wrote:I download Jessie, unzip it. then write to SD. and it worked fine. I did not expand file system. the problem happened after I did update. what do you mean I have to expand file system ?
thanks
Go back and read my post I highlighted how to expand.
The RPi will work fine without expanding until you do an upgrade or attempt to install new software. The un expanded filesystem is only 4G and Raspbian takes up almost all of that leaving only ~115MB to spare...... So you will run out of disk space very quickly. If you run out of disk space during an update then the OS will be trashed and you will have to start again (Win32diskimager).
Lxw2015
Sun Apr 17, 2016 11:36 pm
Rive ,
I did not change default user/pw. after update, I tried default user/pw,( pi/raspberry) did not work.
this is second time this happened.
Luoxw
DirkS
Sun Apr 17, 2016 11:42 pm
Lxw2015 wrote:Rive ,
Luoxw
Just go back to klrick's post: viewtopic.php?f=91&t=144905&view=unread#p955428
and follow his instructions to expand the filesystem.
Lxw2015
Mon Apr 18, 2016 3:30 am
klricks ,
I followed your instruction. expanded file system. and do update. seems no issue found.
thank you.
