CaptSunset
I downloaded the wrong Ninja, what is it?
Sun Apr 17, 2016 7:51 pm
I was trying for ninja-ide, but accidentally installed ninja; an entirely different program which describes itself in apt-cache search as "Privilege escalation detection system for GNU/Linux". It seems to be running in the background using :? 'default' settings, otherwise now invisible...
What does this program do exactly? Is it worth the clock cycles for the average user, and if not, how to I get rid of it when it doesn't show up in System Tools?
paulie
Re: I downloaded the wrong Ninja, what is it?
Mon Apr 18, 2016 8:43 pm
Usual method of installing from the command line:
sudo apt-get install [packagename]
Installing packages requires superuser permissions.
To remove:
sudo apt-get remove [packagename]
To remove, *and* get rid of associated config files:
sudo apt-get purge [packagename]
aptitude is a graphical front-end to apt-get.
It has been my custom to use Xeyes
CaptSunset
Mon Apr 18, 2016 11:45 pm
Thanks for the reply, Paulie;
my concern was being unsure that removing ninja with purge wouldn't remove some 'dependencies' that other programs had previously installed for their own benefit.
