lazydays
Write permissions for external HDD
Sat Apr 16, 2016 9:14 am
Hi guys,
I'm very new to the Pi.
I have a Pi 3 running Raspbian Jessie.
I can see the drive at /media/pi/[my drive name] but I can't create a folder and I've tried to chown to 775 and 777. Neither worked.
I'm logged into terminal as pi.
Any help you can offer would be gratefully received. :)
Re: Write permissions for external HDD
Sat Apr 16, 2016 11:24 am
What's the filesystem on the external HD?
If it's FAT, FAT32, exFAT or NTFS then the security stops at the mount command. Mount it with -o uid=pi,gid=pi,umask=0022
lazydays
Sat Apr 16, 2016 12:38 pm
Hiya and thanks for replying :)
Sorry - HDD is NTFS.
I added this to /etc/fstab - presume that is correct?
/dev/sda2  /mnt  -o  uid=pi,gid=pi,umask-0022  0  2
I haven't formatted the HDD - just plug and play. It shows up with sda1 partitioned to Windows specific and sda2 is the main partition.
When I add the code to fstab it stops the system booting. The only way to get the pi to reboot is to remove or comment out the line above.
Sat Apr 16, 2016 3:52 pm
You need umask=0022 not umask-0022
lazydays
Sat Apr 16, 2016 3:56 pm
Oops - just checked the file and I've used umask=0022
Just a typo in the post.
lazydays
Tue May 03, 2016 3:29 pm
Hi guys,
I'm still having trouble with this - everytime I change fstab it stops the pi from booting up until I remove the line.
Can anyone offer any help?
I'm using a pi3 and Raspbian Jessie.
Thanks!
Sandra
beta-tester
Tue May 03, 2016 4:41 pm
is there an other typo in your post or is it in your fstab...?
the "-o" is a syntax error for fstab it is only a command line option.
try this in your fstab
/dev/sda2  /mnt  auto  uid=pi,gid=pi,umask=0022  0  0
EDIT: i am not entirely sure, but somewhere i read, that the default ntfs driver will mount only as readonly. to have full access to ntfs you have to install and use ntfs-3g
to install:
sudo apt-get -y install ntfs-3g
and then your fstab entry:
/dev/sda2  /mnt  ntfs-3g  uid=pi,gid=pi,umask=0022  0  0
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
