Hi guys,
I'm trying to find some folders that have been placed in the root folder (I need to edit the code inside one of the files). I can access and see the files that are located inside the Root folder fine on LXTerminal, but when I try to access the Root folder from the File Manager, I constantly get the message that my permission has been denied.
Is it possible to access this folder? Or if not, is there a way I can edit the contents of a file through LXTerminal?
Any help would be appreciated,
StevieBruce
Re: Root folder
If the files are visible from the lxterminal it may be simplest to edit them with vi or nano.
Re: Root folder
Edit using any editor, using
sudo <editor> <file>
Re: Root folder
When you open file manager, you can use "View" to show the hidden files if necessary, and "Tools" --> "Open current folder as root" to have access equivalent to sudo. PeterStevieBruce wrote:Hi guys,
StevieBruce
Re: Root folder
Hi guys,
I have slightly the same problem, except that I need to copy a file from the root folder to the home/pi folder and it denies me...
Can anyone help please?
Much obliged
Much obliged
- RaTTuS
- Contact: Twitter YouTube
Re: Root folder
sudo cp /root/file /home/pimirc3a91 wrote:Hi guys,
Much obliged
sudo chown pi:users /home/pi/file
where file is the name of the file
Covfefe
Covfefe
Re: Root folder
For the sudo chown pr:users /home/pi/file command I get the following error: chown: invalid user: 'pr:users'RaTTuS wrote:sudo cp /root/file /home/pimirc3a91 wrote:Hi guys,
Much obliged
Re: Root folder
Look like a typo and should be 'pi:users'
The command changes the ownership of the file to user 'pi', group 'users'.
HTH
Dirk.
HTH
Dirk.
- RaTTuS
Re: Root folder
it was and it is .. sorry about that [updated]DirkS wrote:Look like a typo and should be 'pi:users'
HTH
Dirk.
Covfefe
Covfefe
- ben_nuttall
- Contact: Website Twitter
Re: Root folder
You could run a command to open the file manager window as root.
For example on Ubuntu you could run
However I don't know the name of the file manager app we use on Raspbian.
sudo nautilus
Former RPF staff. Author of gpiozero and creator of piwheels.
Re: Root folder
It's PCManFM (pcmanfm).
ghans
ghans
Re: Root folder
Err... Guys?
I want to copy a folder from /home/pi TO the /root folder... I tried reversing the solution you guys gave up there like this:
"sudo cp /root/file /home/pi" and changed it like this:
"sudo cp/home/pi/file /root"
It gives me an error message saying:
" ' /home/pi/file' : No such file or directory "
I use a Raspbian OS on my Raspberry Pi.
I want to install a Wi-Fi Adapter Driver which goes like this:
"rtl8188EUS_rtl8189ES_linux_v4.1.2.2_5805.20121116.tar"
In the manual, they said:
"For example, to decompress rtl8188C_8192C_8192D_usb_linux_v3.3.0_2920.20111123.tar.gz:
root@driver/# tar zxvf rtl8188C_8192C_8192D_usb_linux_v3.3.0_2920.20111123.tar.gz "
Please Help!
Please Help!
Re: Root folder
Well, this tells me that 'file' does not exist in the home directory." ' /home/pi/file' : No such file or directory "
Have you checked that it actually *does* exist, using 'ls'?
Maybe there's a typo in the name?
Gr.
Dirk.
Re: Root folder
Just run and then copy the files normally.
sudo pcmanfm
Re: Root folder
It doesn't help when someone revives an old topic with "I have the same problem". It is even more unhelpful to revive one to add something to an old post that has already been resolved, even though your solution is slightly different. Don't let this put you off though, there are plently of current posts to help with
Re: Root folder
You can use then use the mv command file is filename
sudo su
mv /root/file /home/pi
