StevieBruce
Root folder
Mon Aug 13, 2012 7:15 pm
Hi guys,
I'm trying to find some folders that have been placed in the root folder (I need to edit the code inside one of the files). I can access and see the files that are located inside the Root folder fine on LXTerminal, but when I try to access the Root folder from the File Manager, I constantly get the message that my permission has been denied.
Is it possible to access this folder? Or if not, is there a way I can edit the contents of a file through LXTerminal?
Any help would be appreciated,
StevieBruce
joan
Re: Root folder
Mon Aug 13, 2012 8:17 pm
If the files are visible from the lxterminal it may be simplest to edit them with vi or nano.
KCarscadden
Re: Root folder
Mon Aug 13, 2012 8:29 pm
Edit using any editor, using
sudo <editor> <file>
vinntec
Re: Root folder
Mon Aug 13, 2012 10:18 pm
StevieBruce wrote:Hi guys,
StevieBruce
When you open file manager, you can use "View" to show the hidden files if necessary, and "Tools" --> "Open current folder as root" to have access equivalent to sudo. Peter
mirc3a91
Re: Root folder
Tue Jun 10, 2014 2:17 pm
Hi guys,
I have slightly the same problem, except that I need to copy a file from the root folder to the home/pi folder and it denies me...
Can anyone help please?
Much obliged
RaTTuS
Contact: Twitter YouTube
Re: Root folder
Tue Jun 10, 2014 2:27 pm
mirc3a91 wrote:Hi guys,
Much obliged
sudo cp /root/file /home/pi
sudo chown pi:users /home/pi/file
where file is the name of the file
Covfefe
mirc3a91
Re: Root folder
Tue Jun 10, 2014 3:01 pm
Much obliged
sudo chown pr:users /home/pi/file
For the sudo chown pr:users /home/pi/file command I get the following error: chown: invalid user: 'pr:users'
DirkS
Re: Root folder
Tue Jun 10, 2014 3:33 pm
Look like a typo and should be 'pi:users'
The command changes the ownership of the file to user 'pi', group 'users'.
HTH
Dirk.
RaTTuS
Re: Root folder
Tue Jun 10, 2014 3:45 pm
DirkS wrote:Look like a typo and should be 'pi:users'
HTH
Dirk.
it was and it is .. sorry about that [updated]
Covfefe
ben_nuttall
Re: Root folder
Tue Jun 10, 2014 5:13 pm
You could run a command to open the file manager window as root.
For example on Ubuntu you could run
sudo nautilus
However I don't know the name of the file manager app we use on Raspbian.
Former RPF staff. Author of gpiozero and creator of piwheels.
ghans
Re: Root folder
Tue Jun 10, 2014 5:54 pm
It's PCManFM (pcmanfm).
ghans
aXeRepublic
Re: Root folder
Sun Jun 29, 2014 4:52 am
Err... Guys?
I want to copy a folder from /home/pi TO the /root folder... I tried reversing the solution you guys gave up there like this:
"sudo cp /root/file /home/pi" and changed it like this:
"sudo cp/home/pi/file /root"
It gives me an error message saying:
" ' /home/pi/file' : No such file or directory "
I use a Raspbian OS on my Raspberry Pi.
I want to install a Wi-Fi Adapter Driver which goes like this:
"rtl8188EUS_rtl8189ES_linux_v4.1.2.2_5805.20121116.tar"
In the manual, they said:
"For example, to decompress rtl8188C_8192C_8192D_usb_linux_v3.3.0_2920.20111123.tar.gz:
root@driver/# tar zxvf rtl8188C_8192C_8192D_usb_linux_v3.3.0_2920.20111123.tar.gz "
Please Help!
DirkS
Re: Root folder
Sun Jun 29, 2014 1:18 pm
Well, this tells me that 'file' does not exist in the home directory.
Have you checked that it actually *does* exist, using 'ls'?
Maybe there's a typo in the name?
Gr.
Dirk.
RaspberryPiFan
Re: Root folder
Sat Jan 16, 2016 1:32 am
Just run
sudo pcmanfm
and then copy the files normally.
Navyscourge
Re: Root folder
Sat Jan 16, 2016 9:19 am
It doesn't help when someone revives an old topic with "I have the same problem". It is even more unhelpful to revive one to add something to an old post that has already been resolved, even though your solution is slightly different. Don't let this put you off though, there are plently of current posts to help with ;)
anonymousr
Re: Root folder
Sun Jan 22, 2017 12:19 am
You can use
sudo su
then use the mv command
mv /root/file /home/pi
file is filename :D
