jkries
Where is my installed program?
Mon Aug 13, 2012 12:41 pm
I am using the Wheezy Debian from the downloads page.
I used "sudo apt-get install libreoffice" to attempt an install. Everything seemed to go fine. Where do I go to launch the program?
Is anyone using a different office package that works better?
mdewey
Re: Where is my software?
Mon Aug 13, 2012 3:56 pm
Assuming it consists of a single program called libreoffice then try typing that at the command line
If you type $PATH at the command line you should get a list of directories in your path. The software should have been installed in one of these.
I have not tested any of that as I am not using that version but it should give you a clue.
zulucat
Tue Aug 14, 2012 9:35 pm
You can also use the Linux command FIND to locate the file. At the command prompt type:
sudo find / -name aFilename
elatllat
Tue Aug 14, 2012 9:51 pm
raspbian> apt-get install libreoffice
Reading package lists... Done
Building dependency tree
Package libreoffice is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libreoffice' has no installation candidate
raspbian> apt-get install libreoffice-common
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 libreoffice-common : Depends: libreoffice-style-default or
                               libreoffice-style
                      Depends: ure but it is not installable
                      Recommends: xfonts-mathml but it is not going to be installed
                      Recommends: libexttextcat-data but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
raspbian> apt-get install libreoffice-java-common
 libreoffice-java-common : Depends: libreoffice-common but it is not going to be installed
raspbian> apt-get clean
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
JeremyF
Tue Aug 14, 2012 10:49 pm
                               libreoffice-style
It depends on Java, but no armhf java. You can use abiword though, I believe.
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
elatllat
Tue Aug 21, 2012 5:27 pm
JeremyF wrote:It depends on Java, but no armhf java. You can use abiword though, I believe.
It said "ure" not "jre".
so far everything else that uses java runs fine.
There is no java vender limitation listed here:
http://www.libreoffice.org/download/sys ... uirements/
related:
http://www.raspberrypi.org/phpBB3/viewt ... =26&t=9633
Return to “Beginners”
