darkbibble
login screen wallpaper changing??
Sun Apr 03, 2016 3:18 pm
how do I change the wallpaper of the login screen??
ive tried googleing it but can only find info from 2012 that's really outdated and doesn't work.
Q; How many Windows users does it take to fix a Linux problem??
A; Whats a Linux problem
Rive
Re: login screen wallpaper changing??
Sun Apr 03, 2016 4:43 pm
Login Screen:
Terminal: sudo nano /etc/lightdm/lightdm-gtk-greeter.conf
Then change:
background = Background file to use, either an image path or a color (e.g. #772953)
Desktop:
Start Menu/ Preferences/Appearance Settings
Navigate to, and then select the image file (Picture), click "ok".
You can change the Desktop color, menu bar color, text color, toolbar font, etc., all from "Appearance Settings".
DNPNWO
darkbibble
Sun Apr 03, 2016 4:46 pm
ive found out how to do it eventually, edit "/etc/lightdm/lightdm-gtk-greeter.conf" and it changes the login screen background
Rive
Sun Apr 03, 2016 4:48 pm
darkbibble wrote:ive found out how to do it eventually, edit "/etc/lightdm/lightdm-gtk-greeter.conf" and it changes the login screen background
hmm
DNPNWO
fruit-uk
Sun Apr 03, 2016 4:57 pm
There is an lxde wallpaper changer/slideshow called lxrotator, only available for PClinux OS I believe, but it may be possible to adapt for the Pi
Frederk
Tue Apr 10, 2018 7:54 pm
Is there a way to make the box invisible, or at least change the dimensions of the box so that its 1 pixel big?
