I really could use some help as I'm now at a total loss as to what do I do next.
what is the PS rated for? Pi3 is 5.1V 2.5A. I am using 5.25V 2.4A myself.George845 wrote:I downloaded NOOBS Version:1.9.0, Release date:2016-03-18.
I'm using the power supply provided with the Pi 3 complete starter kit from CanaKit.
I do not see any /boot/config.txt file on the SD card.
George845 wrote:Output: 5V 2.5A
George845 wrote:Would a VGA issue prevent the keyboard from not indicating NumLock or CapsLock?
Also, what is meant by "The config.txt file is for rasbian jessie. NM."?
George845 wrote:Regarding your first statement, the SD card is plugged directly into a Pi USB port, not into the powered USB hub (I think that's what you're asking).
I agree - the keyboard should have power.
You say: "The config.txt file is in rasbian jessie (which is all that NOOBS has..." I'm presuming you mean that rasbian is the only OS that NOOBS has. That makes sense since within the os folder, there is only a Raspbian folder. However, Raspbian has no jessie item within it. Should I put jessie on the SD card? if so, where do i find it?
The power supply is what i was talking about, and i suggested not powering the pi3 off a USB, but by directly plugging in the 5v 2.5A power supply into 120v-240v outlet. Then plug the mouse and keyboard into the USB ports on the pi3 itself.I have power to the Pi, keyboard & mouse plugged into powered USB hub
Perhaps it is a VGA misconfiguration issue. First, connect HDMI directly to HDTV, If it works, then it is definitely a VGA issue. Ideally you wanted to use an HDMI monitor or DVI Monitor (with HDMI to DVI cable). VGA monitors are....problematic.George845 wrote:Well, I'll be a monkey's uncle! This whole time I was keeping the mini SD card in the USB "carrier", which I now realize is only to access the card on my laptop via USB port.
I've plugged into the mini SD card slot on the bottom of the Pi 3 and I've got things powered up. The keyboard has power, but the monitor screen started out as a dark grey and evolved into fully black now.
What do i do now?
