himani18
How can I view captured images in rpi
Wed Mar 30, 2016 9:55 am
I have implemented the following code..
Everything worked perfectly fine for me..
but I don't know how to view the captured images in rpi...
So Can Anyone tell me how to view the captured images :P
import RPi.GPIO as GPIO
import time
import picamera  # new
sensor = 4
GPIO.setmode(GPIO.BCM)
GPIO.setup(sensor, GPIO.IN, GPIO.PUD_DOWN)
previous_state = False
current_state = False
cam = picamera.PiCamera()  # new
while True:
    time.sleep(0.1)
    previous_state = current_state
    current_state = GPIO.input(sensor)
    if current_state != previous_state:
        new_state = "HIGH" if current_state else "LOW"
        print("GPIO pin %s is %s" % (sensor, new_state))
        if current_state:  # new
            cam.start_preview()
        else:
            cam.stop_preview()
gordon77
Re: How can I view captured images in rpi
Wed Mar 30, 2016 10:00 am
What have you saved ?
I think you need to add something like cam.start_recording('video.h264')
and then cam.stop_recording
himani18
Wed Mar 30, 2016 10:17 am
I have added these new line.
Now how can i view the captured images
import time
import picamera
import datetime  # new
def get_file_name():  # new
    return datetime.datetime.now().strftime("%Y-%m-%d_%H.%M.%S.h264")
sensor = 4
while True:
    time.sleep(0.1)
        if current_state:
            fileName = get_file_name()  # new
            cam.start_preview()
            cam.start_recording(fileName)  # new
        else:
            cam.stop_preview()
            cam.stop_recording()
gordon77
Wed Mar 30, 2016 10:19 am
try omxplayer
himani18
Wed Mar 30, 2016 10:20 am
how to use omxplayer??
gordon77
Wed Mar 30, 2016 10:23 am
type........ omxplayer filename.h264
himani18
Wed Mar 30, 2016 2:12 pm
pi@raspberrypi:~/pi_pictures/video $ omxplayer video.h264
Video codec omx-h264 width 1920 height 1080 profile 100 fps 25.000000
Subtitle count: 0, state: off, index: 1, delay: 0
V:PortSettingsChanged: 1920x1080@25.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
have a nice day ;)
I got this thing... :P
gordon77
Wed Mar 30, 2016 3:46 pm
Is it showing the video ?
JimmyN
Wed Mar 30, 2016 3:50 pm
himani18 wrote:pi@raspberrypi:~/pi_pictures/video $ omxplayer video.h264
Looking at your script "video.h264" is not the file name you saved it as. You used "%Y-%m-%d_%H.%M.%S.h264" as the filename. You'll need to look at the file you saved and use the actual file name to play it.
ls -l ~/pi_pictures/video
ETA: You got the "Have a nice day" termination message because it couldn't find a file named "video.h264"
